low boost/ low power
Old Sep 28, 2010 | 09:00 PM
desertrat64's Avatar
desertrat64
Question low boost/ low power
i have been reading all the posts about how everyone is pushin 20psi of boost and i cant even get my truck to do that even when im towing does anyone know what the problem could be??
Old Sep 28, 2010 | 09:20 PM
fordpride's Avatar
fordpride
a bone stock truck should hit 15 to 17 psi if it's not then try and unplug you MAP sensor and see if it helps and check the hose going to it to see if it's stoped up
Old Sep 28, 2010 | 09:23 PM
desertrat64
if i unplug it wont that throw a code?
Old Sep 28, 2010 | 09:26 PM
fordpride's Avatar
fordpride
yea it will but when plug it back in after a few miles it will go away
Old Sep 28, 2010 | 10:51 PM
desertrat64
oh ya huge difference ill pick up a new map sensor tomorrow
Old Sep 28, 2010 | 10:54 PM
fordpride's Avatar
fordpride
make sure it's not the VAC. line going to the MAP frist take it loose from the MAP and see if you can blow in it
Old Sep 28, 2010 | 10:59 PM
desertrat64
ok cool thanks
