Modular V10 (6.8l)
Pulling My V10 Engine out?
Old Oct 5, 2010 | 04:51 PM
MiniFormulaIndy's Avatar
MiniFormulaIndy
The Hoist I used was not the Harbor Freight one, or Auto Parts Store brand, those won't go high enough. (at least that I'm aware of) I used the rental type with an extension arm, that slides out of it. It has to come over the top of the entire front end. It is high. It'll come out and you can leave the entire front end intact.
Old Oct 5, 2010 | 06:48 PM
bill11012's Avatar
bill11012
Modular motor junkie
Mine is the 2 ton folding hoist from Harbor Freight. I pulled the front end off the truck, so height was no issue.
Old Oct 5, 2010 | 07:37 PM
mwsF250's Avatar
mwsF250
I used the HF non-folder. Actually, I've used it about 30 times now! Surprised how durable it's been consideringthe the source. If you leave the tranny behind, it will handle this engine with extension out to the 1 ton position.
Spend an extra hour and FIRST remove the grill, radiator, fan, and front bulkhead (it all unbolts). The only PITA is the A/C condenser, that has to be carefully tied to the side and protected (unless you drain refrigerant and remove hoses). Then you have an opening all the way down to the bumper level. Not only makes it easier to remove engine when ready, but makes it easy to step over the bumper so you can stand in the hole to work. Leaning over the grill gets so old....
Old Oct 5, 2010 | 10:44 PM
Cooper24's Avatar
Cooper24
Thanks for the info...what about an engine stand? Is 1000# enough? or would 750# be enough?
Old Oct 6, 2010 | 11:27 AM
bill11012's Avatar
bill11012
750 is enough, but I would go for the 1,000.
Old Oct 6, 2010 | 07:16 PM
mwsF250's Avatar
mwsF250
I think mine was 750... It held, but boy did it deflect! It is welded with the pivot pointing upward, but my engine ended up pointing down slightly down.
Old Oct 6, 2010 | 08:09 PM
Mr-Pipeline's Avatar
Mr-Pipeline
Here's is a link to the thread that details my engine swap. You can look at my albums by clicking on my user name and view my albums. I have them seperated by topics. I removed the hood and pulled the entire front end except the condenser. I guess it's possible to leave the radator and front end stuff but space would be limited at best. Check out the thread link below...I documented almost every step. Good luck, keep us posted.
https://www.ford-trucks.com/forums/9...2000-f350.html
ak-angler
Modular V10 (6.8l)
302
Nov 25, 2023 02:39 AM
knuss3807
Apr 20, 2016 07:26 AM
RideDiesel88
Apr 5, 2014 01:25 PM
coolguy1419
May 11, 2010 06:37 PM
