Vacumn pump
Old Sep 28, 2010 | 01:58 PM
Mike8623's Avatar
Mike8623
Vacumn pump
How hard is it to change the vacumn pump on a 96 powerstroke? Is there a writeup any where? any suggestions?
Old Sep 28, 2010 | 02:06 PM
Talyn's Avatar
Talyn
Really easy, You just need a puller to pull the pulley and press it back on.
I did mine a few weeks back. Expensive for the pump, but kinda needed.
Are you having braking issues?
I lost my brakes when mine went bad.
Otherwise you could just have a vacuum leak.
Old Sep 28, 2010 | 02:09 PM
Action4478's Avatar
Action4478
You will need these :Name:  Pully puller tools.jpg
Make sure you put the bolts in behind the pulley ,before installing it ...
Old Sep 28, 2010 | 02:18 PM
Mike8623's Avatar
Mike8623
Well my ebrake light is intermittantly coming on and going off, when it comes on it kicks off my cruise control........someone on here suggested the vacumn pump.
Brakes work fine so far......it is just that dang light and the cruise control thingy
Old Sep 28, 2010 | 02:19 PM
Talyn's Avatar
Talyn
The brake light comes on when there is a brake error.
Could just be the sensor on the master cylinder though as well.
Old Sep 28, 2010 | 03:04 PM
95 F-350 psd's Avatar
95 F-350 psd
like talyn said it might be the sensor on the master cylinder,it was on my 95 stroker,my brake light wasnt coming on but the cruise control would kick off intermittantly, i had no idea what it was,until i got a recall notice,and it was for the sensor!!
