no compression
Old Sep 27, 2010 | 11:07 PM
Jbrown8988's Avatar
Jbrown8988
no compression
i have an 2000 f-250 5.4L the truck has had a intermitent skip for a couple months... but thought nothing of it as it was usually just a coil. 210,000 miles on it. Well tore into it tonight to figure which coil needed to be replaced and to find out the #4 cylinder has 0 compression... NOW WHAT???
Old Sep 27, 2010 | 11:08 PM
Jbrown8988's Avatar
Jbrown8988
should also add that the exhaust manifold on that side was leaking for a while and replaced that a few weeks ago.
Old Sep 28, 2010 | 09:59 AM
Skoda's Avatar
Skoda
first do the test again... maybe even with another gauge, if it's still zero then tearing into the motor should be considered. or even a new motor
with a code reader does it indicate that theres a missfire for cyl4?
Old Sep 28, 2010 | 11:39 AM
Jbrown8988's Avatar
Jbrown8988
no codes. But get this... after drinking a lot of beer last night we left it and now it is running fine!!! what the heck?
Old Sep 28, 2010 | 04:55 PM
Skoda's Avatar
Skoda
could be a bad cop your after as for the compresion check were was the mark on the crank hub when you did it?
Old Sep 28, 2010 | 05:01 PM
Jbrown8988's Avatar
Jbrown8988
no the cop is good... not sure about the mark on the crank. what does that the position have to do with testing the compression? (not being a dick, i am curious... just dont no how to word it different)
Old Sep 28, 2010 | 10:30 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
I think he assumed you did a leakdown test.
Old Sep 29, 2010 | 11:38 PM
fixnair's Avatar
fixnair
My 4.6 Intech (01 Lincoln Cont. W 155000 miles) lost compression on #6 cylinder and I pulled just that head and found a burned Exhaust valve.
F53&Expedition
Dec 2, 2016 11:03 AM
Wheresmikeys
Engine Swaps
Jul 9, 2016 10:41 AM
MSwitchblade
1997 - 2003 F150
Jul 15, 2015 10:55 PM
R1ch
Feb 24, 2015 06:13 PM
fordiesel69
Oct 31, 2013 12:02 AM
