6.0 turbo problem
Old Sep 27, 2010 | 07:16 PM
f350custom's Avatar
f350custom
6.0 turbo problem
from what i am finding out the 6.0 turbo has some problems with the plate inside it . it get rusty an carboned up an then sticks so i am guessing the main one is it gets rusty so what would happen if we took it a part for a cleaning an i sent the plate out to be jet hot coated ??? that should stop the rust an it should run cooler right ???
Old Sep 27, 2010 | 07:18 PM
gearloose1's Avatar
gearloose1
Apparently a later turbo design has a coating.
I though of the same idea, but my turbo has maybe 200,000 miles on it... so why bother.
You are being an alpha tester (brave) but let us know...
I had mine cleaned... and am doing an Italian tuneup once a month to keep rust off it.
Old Sep 27, 2010 | 07:20 PM
lakewood's Avatar
lakewood
I just had my turbo replaced, the new remans have an anti-sticking coating on them
Old Sep 27, 2010 | 07:30 PM
f350custom's Avatar
f350custom
what is a italian tune up an is it working ????
Old Sep 27, 2010 | 07:35 PM
gearloose1's Avatar
gearloose1
See signature.
Old Sep 28, 2010 | 07:02 AM
f350custom's Avatar
f350custom
im thinking some sort of coating like jethot would be the way to go. the only thing i am worried about is the jet hot taking up the clearences so maybe having the plate machined down a little would help to ?
Old Sep 28, 2010 | 03:06 PM
amgpro2's Avatar
amgpro2
I thought about polishing the surface of the unison ring/plate as well as the housing. I had my turbo cleaned less than 1k miles ago and it is also sticking.
Old Sep 28, 2010 | 04:52 PM
woodlander's Avatar
woodlander
Hmmm maybe I should spray some PAM up my intake
Old Sep 28, 2010 | 04:57 PM
Heckler's Avatar
Heckler
This is interesting as a polished surface will not rust as easily as a porus surface.
Also makes me wonder why with turbos being so expensice that they are not made from stainless steel...
Old Sep 30, 2010 | 08:32 AM
f350custom's Avatar
f350custom
i am not saying polishing is going to do anything but what i am trying to do is stop the rust because that seems to be one of the problems with these turbos that ford an some othere people are saying an i have seen it my self the rust on the unison ring is a problem so thats why i was thinking that have it jethot coated it might stop or at least slow the rust down because jethot can handle a lot of heat . a friend of mine has a set of coated headers that we had cherry red before an it had no real affect on the coating so i was just wondering what you people thought ??
Old Sep 30, 2010 | 09:12 AM
gearloose1's Avatar
gearloose1
The big question: will the coating withstand the heat, and not cause the parts to stick?
A coating for the outside of headers is quantitatively a different animal than a coating that have to take a moving part sliding around.
kbuchheit
Jun 25, 2021 11:44 AM
Jeremy2792
Nov 24, 2013 08:46 PM
dkean1
2009 - 2014 F150
15
Dec 21, 2012 05:03 AM
thomas5853
Jun 19, 2011 10:04 PM
Rusty Axlerod
Feb 10, 2011 06:30 PM
