Backfire under acceleration how do I fix it?
Old Feb 26, 2011 | 09:14 PM
  #46
supercabfreak's Avatar
supercabfreak
id say its more so in the timeing and may be a little rich on the idle side. regaurdless what ford/ FTE useres say its suposed to be, ive found that i have to run my 360 at 0-2 degrees btdc any before that and it won run and any after that it runs ok but experiances the same problems as described before.
i may be running it a lil early to compensate for another problem im haveing but it has loads of power and torqe and my mileage has improved insignifigantly. just my 2 cents
Old Feb 26, 2011 | 09:46 PM
  #47
Sleepy445FE's Avatar
Sleepy445FE
whatever you decide to do, don't put a 750cfm carb on a 360.
The formula for selecting carb size: VE(volumetric efficiency) X Cubic Inch X max rpms / 3456.
A 500cfm is just right for a 360. 600 is not too bad though.
Old Feb 28, 2011 | 12:16 AM
  #48
jlaudio_f100's Avatar
jlaudio_f100
I would like to keep the carb that's on it. I haven't been doing anything with this truck because it has a flat tire right now. I want to drive it this summer so I need to figure out this problem. I need to get a set of tires too.
Old Mar 18, 2011 | 01:36 AM
  #49
jlaudio_f100
I am at the point where I think I will just drive the crap out of it this summer and when winter hits I will pull the engine and replace all the gaskets and seals as well as put a new timing chain kit on. I bet I have a leak in the intake manifold. It is seeping coolant out between the intake and head in one spot. Its a very tiny amount but that tells me its not 100% sealed. It is not enough to even drip. There is no oil in the coolant or coolant in the oil. I figure I will just suck it up and drive it as is for awhile. I only use it for off road driving anyway. I am not saying I wont drive it somewhere else but I cant afford the gas to just cruise around at 8mpg.
Old Mar 18, 2011 | 02:14 AM
  #50
HeeHaw78's Avatar
HeeHaw78
so what size carb should one put on a 429? not sure what it came from or anything about it other than it has a 4bbl carter afb on it. and when i am driving and punch it you cant even feel the 4bbl kick in. it is not a vacuum setup its a linkage setup. maybe its just not big enough. i have not been able to figure out which carter it is.
Old Mar 25, 2011 | 02:22 PM
  #51
nathanfordman's Avatar
nathanfordman
back freing
hi my name is nathan i have an 86 ford i have an 85 motor in it i have replaced all most everthing but the carb when i give it alot of gas it backfires what do u think it could be could it be the coil going bad
Old Mar 25, 2011 | 02:28 PM
  #52
nathanfordman
its a 302 small blck
Old Mar 25, 2011 | 03:15 PM
  #53
peganit2's Avatar
peganit2
weak spark will do that too. Try closing the spark plug gap .010"
Old Mar 25, 2011 | 04:19 PM
  #54
nathanfordman
mines the same way what do u think it is
Old Mar 25, 2011 | 10:04 PM
  #55
jlaudio_f100
I know I have good spark. I replaced everything. iridium plugs, new wires, rotor, cap, coil.
Old Mar 26, 2011 | 05:58 PM
  #56
nathanfordman
hey pal what eles would make the truck backfire
Brnfree
Apr 19, 2015 11:18 AM
hillcountryflt
Oct 29, 2014 08:44 PM
jhweigel
Jul 19, 2014 11:01 AM
pintoches
1978 - 1996 Big Bronco
Oct 27, 2012 07:29 AM
gearhed1971
Apr 8, 2007 08:10 AM
