i have a 2005 excursion psd that is having severe acceleration issues. sometimes not always when taking off from a stop the gas pedal will go to the floor and the truck will just idle and sometimes idle low and stall. i checked for codes and there was none. i cleaned the egr 2 weeks ago and that didn't do it so i took it to the dealership. they said it was the TPS and that it was $800 being that it is the adjustable pedal. i told them i thought that was a little to much for a freaking pedal and they agreed. the mechanic said he would try and put a fixed pedal in instead for $170. he put it in and it worked great for a week and a half. tonight i'm at work and my wife calls and tells me the gas pedal is not working again and its stalling. i spent a total of $450 at the dealer last week for something that didn't solve the problem. i'm hoping someone can tell me what the problem is so i don't have to waste any more money. my x has 105,000 and is not under warranty. any help would be appreciated
I don't know what a fixed pedal is but that is where I would start if you are not getting any codes. Since the "fixed" pedal had resolved the problem the first time can you verify it hasn't failed again?
I assume you have changed your fuel filter regularly? What are you using to read codes? Truck does this in gear and in park?
a fixed pedal is a non-adjustable pedal, it doesn't adjust to the height of the driver. to check for codes i bought a POCKETSCAN PLUS from advance auto. the fuel filter and oil filter have been changed within 1000 miles. the truck has this problem in gear . the egr was cleaned less than 2 weeks ago and it was filthy. i also cleaned and vaccumed out the chamber in which the egr is housed. right now i can't rev the engine to 3000 because my wife took it to work. she drives it with 2 feet, one always on the gas pedal as to never lose the throttle and the other one to break.(not very safe in ny traffic). when she gets home i will rev it up. what i'm i looking for when i do this or will it just clean the carbon off a sensor? what exactly is an Italian tuneup?
like i said i cleaned the egr and i vacuumed out the egr houseing which i guess is called the plenum and that has not fixed the problem. it was done 2 weeks ago should i do it again? i have only owned this truck for about 2 months and i use diesel kleen every time i fill up.
when my wife came home i took the truck out and rev'd the engine up to 3000 rpm a quite a few times and it seemed to run find. this morning i drop my son off at school and on the way back i lost the throttle again. the gas pedal went to the floor and i coasted into my driveway. any other ideas on what to do?
Without going into a 500 word post detailing why what you are suggesting is not likely to work --- and explaining to you things like what is an intake / exhaust valve.
If you want that, it is consulting under my regular rates.
If you don't know what intake/exhaust valves are, it is time to take this issue to a qualified Ford Technician.
