Sponsored by: Real Truck
2V vs 3V
Old Sep 26, 2010 | 06:19 PM
Haulin550's Avatar
Haulin550
Question 2V vs 3V
Hey guys new member with a question about my 99 F550 6.8L. I use the truck to pull my 32ft 5th wheel and so it sits most of the time. It’s an automatic and two wheel drive. It’s a great truck but like many of you already know it’s a little short on power especially when pulling steep grades. I’ve heard the 3V engine is much better and responds well to performance modifications. I know it would be expensive to swap out my old motor for a new 3v but if the power gain is there then perhaps it would be worth it. My question is (actually got a lot of them) would the power gain be worth it? If I did the swap what else would need to be changed. What modifications to the 3V would you recommend before it was installed? Could I get similar power from some of the normal modification to the 2V motor?
Old Sep 26, 2010 | 06:31 PM
spinella's Avatar
spinella
cant really answer your swap questions...but have you considered a gear change? or a tuner? my tuner made a big difference for me while towing.
Old Sep 26, 2010 | 06:41 PM
Haulin550's Avatar
Haulin550
I have considered both, talked to one of the local parts suppliers and he did not recommend a tuner. He said he’d had seen only 20 to 30hp gain with them. Which tuner did you use? A gear change is also on the table if it gets me what I'm looking for. Not sure what my current gear is thou. The motor is usually running about 2500 at 60 mph so I'm guessing it’s a 3.73.
Old Sep 26, 2010 | 06:53 PM
spinella's Avatar
spinella
i have a SCT tuner from mike at 5 star tuning. heres his link. 5 Star Tuning | Custom Dynomemeter Chassis Tuning Products and Services it helped me with my camper. i have 3:73 and when i can afford it i am going to change them (4x4) probably 4:56's
Old Sep 26, 2010 | 06:58 PM
Haulin550's Avatar
Haulin550
Thanks spinella I will check them out. What other modifications have you done or recommend? What size trailer do you pull?
Old Sep 26, 2010 | 07:24 PM
spinella's Avatar
spinella
my camper is 36ft. 9000lbs. i also added a s&b air box from mike. i like it because i can clean the filter and re-use it. i would like to add the big trans cooler that came with the 6.0's i think its a 31 core. its a little pricey @ $400 but i heard its worth it. i also want o add a temp gauge for the tranny.
Old Sep 27, 2010 | 08:19 AM
DAVE67FD's Avatar
DAVE67FD
So your looking at about a 50hp difference (2v vs 3v). IMO the tuner and gear swap will yield you similar power trade off's vs cost.
Unless you have the ability and the resources to do a cheap 2v/3v swap.
Old Sep 27, 2010 | 08:34 AM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
Hi Haulin550
I suspect your F550 has 4.30 or 4.88 gears already, double check that with a door jam axle code. As already suggested a tuner can help to correct the terrible factory fueling which will help in addition power and torque. I would also look at your exhaust and maybe replace the factory ypipe.
Mike
ps Hi Ed hope all is well with you.
myakkacracka
13
Jun 16, 2016 11:33 AM
myakkacracka
Mar 17, 2014 07:35 AM
usmcdaveII
Nov 14, 2013 09:50 AM
TexasEX2K
Jul 5, 2012 10:46 PM
donniezyea
Mar 6, 2012 11:27 PM
