Charging System
Old Sep 26, 2010 | 01:45 PM
soberdude94's Avatar
soberdude94
Charging System
I have had to replace my altanater 2 in the last 8 weeks this time I put it on and started the truck the Altanater light is still on I am confused I had the parts store bench test this one before I took it does anyone have any experience with this issue or have a clue what I should look at next?
Old Sep 26, 2010 | 02:10 PM
gearloose1's Avatar
gearloose1
Check your batteries.
Check the alternator pigtail (or just replace it).
IF I were to lay a guess... pigtail.
Old Sep 26, 2010 | 02:17 PM
soberdude94
I will check it do you have any Idea of who would be open on sunday that might have a new pigtail to replace it with?
Old Sep 26, 2010 | 02:26 PM
gearloose1's Avatar
gearloose1
IMHO, the pigtail is pretty widely available because many Fords use the identical part.
Ford markets a "kit" that have the pigtail, crimp connectors, shrink tubing, etc. to do a perfect job... but the cost is $$$
I would walk in with a pic (or yours) in your hot little paws and ask for them to match it up for you.
Call NAPA, Autozone, etc. around you to make sure they have it in stock before you go...
Old Sep 26, 2010 | 02:45 PM
soberdude94
Thanks Gear I will check it out now
Old Sep 26, 2010 | 03:09 PM
soberdude94
Hey gear I was reading I am curious are you refering to the 2 wire thin aass wire pig tail or the single heavy wire on the altanater ?
Old Sep 26, 2010 | 03:10 PM
gearloose1's Avatar
gearloose1
2 wire pigtail.
My experience is there is a high probability of an internal break (right where the wire goes into the molded part) and it is often:
a) intermittent
b) a pita to isolate
Visualize the engine shaking around, that joint takes a lot of stress.
On the replacement pigtails, there is a stress relief (a tube like structure) that comes out of the molded part.
Testing it at the connector may not reveal the break --- when it intermittently makes contact.
Another suspect is the connector itself and the solder / wire crimp joint inside.
I don't have an X-ray machine... but that is a sure way to reveal an internal fault without replacing it!
Old Sep 26, 2010 | 03:19 PM
soberdude94
hell cheap to replace and a whole lot less time than the other time = money i will replace the pig tail
Old Sep 26, 2010 | 03:23 PM
gearloose1's Avatar
gearloose1
Post replacing pigtail --- check voltages of sense wire, as well as exciter to ensure it is on spec.
Details in link below.
If you are not getting battery voltage at the sense wire --- you got a problem in that circuit all the way back to the batteries.
Old Sep 26, 2010 | 03:26 PM
soberdude94
Wich wire is the sensw wire and what is the exciter? I am here to learn and the only stupid question is the one we dont ask
Old Sep 26, 2010 | 03:39 PM
gearloose1's Avatar
gearloose1
Get the alternator diagram for your vehicle (whatever generation it is) and the color of the wire should be labeled.
Ford Fuel Injection Alternator Files
Note:
Wiring color may not be exactly the same as the diagrams.
Old Sep 26, 2010 | 03:42 PM
Hardman's Avatar
Hardman
If it same as mine the one one passenger side OG/LB koeo should be battery voltage and driver side LG/RD 1-3v and around 9v koer
daisyq31
Escape & Escape Hybrid
May 8, 2013 10:25 AM
joe blow
Apr 1, 2009 04:53 PM
Fabman54
1947 and Older Ford Trucks
19
Nov 25, 2008 06:15 PM
