2004 Throttle butterfly
Old Mar 30, 2009 | 02:28 PM
joe blow's Avatar
joe blow
Hello,
I finally got a chance to do my CCV mod and unfortunately had to replace the main elbow feeding the turbo, the silicone hose right off of the turbo and the black one feeding the intake manifold...ALL ruined from oil.
I did remove the intake elbow and discovered I indeed do have the "butterfly" in the intake elbow of my 2004 PSD with build date of 11/03
What is the purpose of this thing?
What does it do?
Is it helping me or hurting performance? If so, is it removeable without messing things up?
Thank you
Old Mar 30, 2009 | 02:56 PM
natem8301's Avatar
natem8301
Originally Posted by joe blow
Hello,
What does it do?
Thank you
Someone more knowledgeable will be able to give you a for sure answer but i think its stagnant....I dont think they programmed any functionality for that part...If you look in the 6.0L bible i think it gives a good explaination there.
Old Mar 30, 2009 | 08:21 PM
joe blow's Avatar
joe blow
I wonder if it is only a cold start thing....I wish I knew what the h*ll it did.
Old Mar 30, 2009 | 09:53 PM
nghtrgr's Avatar
nghtrgr
I believe on 03 it functioned with the EGR valve...it blocked flow of air when EGR allowed exhaust gas into the intake. But I believe its function was stopped through programming on the 04's. I as well as others have removed the "disc" part in an attempt to get a little bit more flow which alleviated some symptoms of PMS....Powerstroke Modification Syndrome....he he he
Old Mar 30, 2009 | 11:08 PM
joe blow's Avatar
joe blow
Did you remove the "disc" within the throttle body?
Did you experience any problems?
Old Mar 31, 2009 | 10:42 AM
natem8301's Avatar
natem8301
Page 37 of the 6.0l bible says 03's its not operational 04's it "may" be operational. That doesnt help much I know, but I couldnt find anything else..
Old Mar 31, 2009 | 10:49 AM
nghtrgr's Avatar
nghtrgr
I have no problems will look around some more. There are more posts with smarter people than me repling to the same subject. I will see what I can find.
Old Mar 31, 2009 | 02:58 PM
joe blow's Avatar
joe blow
Cool thank you buddy
Old Mar 31, 2009 | 07:42 PM
sonneborn3's Avatar
sonneborn3
I also have an 04 and I removed mine last summer, with no problems. Just don't drop the bolts into the intake!
Old Mar 31, 2009 | 08:06 PM
joe blow's Avatar
joe blow
Did it today, no problems so far. What about removing the rotating shaft?
Did any of you do that?
Old Mar 31, 2009 | 09:17 PM
nghtrgr's Avatar
nghtrgr
I did not, eventually I would like to.
Old Mar 31, 2009 | 09:27 PM
ocboat's Avatar
ocboat
Hello,
Were you able to buy a new black boot that connects to the elbow at the intake? I just noticed that mine is leaking pretty bad. Thanks.
Old Mar 31, 2009 | 10:21 PM
Lubbockguy1979's Avatar
Lubbockguy1979
The new ones are blue and suppost to be better quality
Old Apr 1, 2009 | 04:20 AM
sonneborn3's Avatar
sonneborn3
I left the shaft in there
Old Apr 1, 2009 | 07:48 AM
joe blow's Avatar
joe blow
oc boat,
yes i did. The main elbow to the compressor wheel (cold side) was 58.00, the blue off the other side of the turbo was 24.00 and the black that connects the elbow to the intercooler tube off the front of the manifold was 54.00?!?!?!?!? Makes no sense why the one on the front cost as much as the 4" hard elbow that feeds the turbo....but there you have it....I took it in the shorts on that one.
Good Luck
