Cracked block.
Old Sep 25, 2010 | 07:10 PM
mabc926's Avatar
mabc926
Cracked block.
How can you check for a cracked engine block?
I'm asking cause I finally got my truck home today and it was sitting in my yard and some guy stopped at my house and starts telling me how his friend use to own the truck!
Well we sat there and talked awhile and then he told me that last he knew the truck had two bad head gaskets and a cracked engine block.
(I was told by the guy who sold it to me that it had two bad head gaskets, but he said nothing about a cracked block)
So I just want to check it out before I do much more to it.
If I find out it has a cracked block one of two things will happen, #1 sell the truck or #2 put in a 6.9
Old Sep 25, 2010 | 07:59 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
is it full of oil and coolant and running yet or?
Old Sep 25, 2010 | 08:35 PM
94 smokin stroker's Avatar
94 smokin stroker
it can be magnafluxed i think thats what its called
Old Sep 25, 2010 | 09:21 PM
mabc926's Avatar
mabc926
Not yet, I still have to rebuild the oil cooler, but I was wanting to find out if the block is ok before I did that.
Old Sep 25, 2010 | 09:38 PM
joe f350's Avatar
joe f350
get a comption tester
Old Sep 25, 2010 | 09:42 PM
mabc926's Avatar
mabc926
Get a compression tester, compress each cylinder and look for air bubbles in the coolant?
Or I could get the engine running and then look for bubbles in the coolant.
Man this sucks.
Old Sep 25, 2010 | 09:46 PM
joe f350's Avatar
joe f350
idt ur block is cracked test ur compression frist and go form there if u have a dead cyclearnd u know or get a rad perhure tester and see if it leakes
Old Sep 26, 2010 | 12:30 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
7.3's are more likely to develop pin holes in the cylinder walls then crack.
The best way to test for cylinder leakage problems is to remove the rockers, remove the Glow Plugs, then air charge each cylinder watching for bubbles in the radiator.
Warning! The motor will turn over as you are applying the air charge as it pushes the piston to the bottom of it's stoke, to get a good proper test the piston must be at BDC.
-Enjoy
fh : )_~
Old Sep 26, 2010 | 05:35 AM
oreocreaming's Avatar
oreocreaming
x2 on festus, but adding you should squirt some oil into the cylinder first. that will help the air from escaping past your rings and help give you a more positive picture on leaking areas. the procedure is called a leak down test.
Old Sep 26, 2010 | 04:39 PM
Festus Hagen
Methanoholic
The problem with squirting oil in a precupped V8 is the oil will never get on the Higher 2/3 of the cylinder bore!
It will just puddle on the low side!
In a V8 gasser you squirt the oil to the high side of the piston and allow it to run around the bore.
-Enjoy
fh : )_~
Old Sep 26, 2010 | 05:37 PM
fonefiddy's Avatar
fonefiddy
Generally speaking, If the block is cracked, You'll know it. It'll leak, or pressurize to a point of something failing.
IF the truck runs good, drive it!
Old Sep 26, 2010 | 05:47 PM
Festus Hagen
Methanoholic
I agree fonefiddy, run her till she shows real signs!
-Enjoy
fh : )_~
Old Sep 26, 2010 | 07:18 PM
mabc926's Avatar
mabc926
That's the funny thing, this truck has NO oil or coolant leak at all!
Beats me, maybe the guy was just full of ****.
So anyways I'm just going to fill the oil up and run the truck and see what happens, the worst it could do it trash the engine and if it already had a crack that's no big deal, or it could run just fine.
I can tell you right now though, this is the last time I buy a truck with out knowing the full story behind it.
Thanks for all your input guys!
Old Sep 26, 2010 | 08:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle
A blown head gasket or cracked block would probably put coolant in the oil long before it put oil in the coolant.
Do the test with shop air in the glow plug hole and the rockers removed.
Before you apply air pressure to the cylinder, fill the radiator completely full.
When you put air pressure in the bad cylinder/s, the water will overflow.
If you don't get the water running out of the radiator, the problem is somewhere else.
If you do get water running out of the radiator, you know which cylinder/s you need to concentrate on with the inspection when you tear it down.
As you clean up the head gasket area, you can see a crack.
Old Nov 13, 2010 | 02:10 PM
Scratcher's Avatar
Scratcher
Cracked block
edited by Scratcher
