You slide it in there and leave it so that the connector can't physically move enough to work itself loose... here's a link for ya that's got some good pictures:
Just remember if you do this mod, retorque the injector and rocker arm bolts. The specs are around here somewhere... I'm sure someone will post up. But I would check your pump and strainer first. Also, make sure that you have clean filters.
You slide it in there and leave it so that the connector can't physically move enough to work itself loose... here's a link for ya that's got some good pictures: https://www.ford-trucks.com/forums/9...ml#post8540088
To properly fit, those quarters have to be cut down to the top of George's head. They end up being slightly "D"-shaped as a result.
