While turning it sometimes makes a funny noise, kinda like a slight clunk. There is a lot of play in the joint that connects the Tie Rod and the Drag Link. I got these part names from my Hayne's manual and they do not describe the connector (which is like a ball joint) other than to say "cotter pin." Sheesh. Anyway, I could really use some help with the name of the part, how to replace it, and what kind of tool I need to rent/buy.
BTW I just did upper control arms and ball joints on a '97 with torsion bars so I'm already geared up for more ball joints!
you might have to take a picture of what your talking about. Its either a tie rod, center link, adj sleave, pitman arm, ball joint. Thats all there is under there. So its going to be one of them. I just dont know what your talking about....
