Good scanner for pulling codes?
Old Sep 24, 2010 | 04:32 PM
High Binder's Avatar
High Binder
Hey guys, I'm wondering what you guys use (for a home application) for pulling random codes and anything else you might use it for.
Thanks!
Old Sep 24, 2010 | 06:32 PM
gearloose1's Avatar
gearloose1
I use a $50 code reader... the pros spend $$$ for Autoengenuity with the Ford Diesel package.
Old Sep 24, 2010 | 06:44 PM
hifiman's Avatar
hifiman
I bought a new Scan Gauge II and love it. I would suggest reading the reviews and threads on this forum as there are quite a few of us that own them. As well as codes there are many gauges so you can keep an eye on things while driving. I bought mine for 159.00 with free shipping.
Old Sep 24, 2010 | 07:39 PM
High Binder
Awesome, I'm reading reviews now. Can you delete codes with it as well?
Old Sep 24, 2010 | 07:53 PM
rocky1074's Avatar
rocky1074
YES
Pressing the CLEAR button will result in a prompt from the
ScanGaugeII to verify that you want to clear the trouble code(s) and turn off the “Check Engine” lamp.
Old Sep 24, 2010 | 08:08 PM
amadas350's Avatar
amadas350
doesn't the scan gauge II only measure the coolant temp tho, so for us to compare the ECT vs EOT we would need a diff gauge?
Old Sep 24, 2010 | 08:53 PM
rocky1074's Avatar
rocky1074
I have the Edge Insight. It will monitor Oil Temp;Coolant Temp;Boost; Volts & EGT with optional probe. It does not monitor Fuel Pressure you would need another gauge for that. I don't think they make it anymore. It was replaced with the Insight CTS & CS You can check them out.. Edge Products| The Leaders in Performance Electronics
Hopefully someone with the CTS or CS will jump in and give you more info!!!
Old Sep 24, 2010 | 10:39 PM
lechonera's Avatar
lechonera
sorry, disregard..
Roberto.
Old Sep 24, 2010 | 10:57 PM
RedEagle58's Avatar
RedEagle58
No, the ScanGauge II will monitor many different functions. I have my main set up for Volts, TFT (transmission temp), EOT and ECT (shows as *FWT).
Old Sep 25, 2010 | 01:21 AM
amadas350's Avatar
amadas350
Well I knew it measures 12 things,
I had heard that people were using them for EOT vs ECT. But on website it list coolant as one of 12 functions and oil temp is not. That is why I was wondering.
Copy and pasted off of website.
<table border="0" cellpadding="5" cellspacing="0" width="100%"><tbody><tr> <td class="hdl14_gray" valign="top">Fuel Economy </td> </tr> <tr> <td class="hdl14_gray" valign="top"> Fuel Rate </td> </tr> <tr> <td class="hdl14_gray" valign="top">Battery Voltage </td> </tr> <tr> <td class="hdl14_gray" valign="top">Coolant Temperature </td> </tr> <tr> <td class="hdl14_gray" valign="top">Intake Air Temperature </td> </tr> <tr> <td class="hdl14_gray" valign="top">Engine Speed (RPM) </td> </tr> <tr> <td class="hdl14_gray" valign="top">Vehicle speed (MPH and KM/H) </td> </tr> <tr> <td class="hdl14_gray" valign="top">Manifold Pressure
(not available on some vehicles)</td> </tr> <tr> <td class="hdl14_gray" valign="top">Engine Load </td> </tr> <tr> <td class="hdl14_gray" valign="top">Throttle Position </td> </tr> <tr> <td class="hdl14_gray" valign="top">Ignition Timing </td> </tr> <tr> <td class="hdl14_gray" valign="top">Open/Closed Loop </td></tr></tbody></table>
Old Sep 25, 2010 | 01:29 AM
amgpro2's Avatar
amgpro2
on Scanguages web site look at the x gauge that it supports. You can program up to 25 additional gauges. They have a vehicle specific data sheet that you can use to program the gauges. EOT is one of them.
Old Sep 25, 2010 | 07:36 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
The codes can only be cleared at first key on. Wont clear while you drive. Not sure if that is just how it is with all code readers or not.
Mine always shows ECT (fWT) and EOT. The other 2 I switch to different gauges as I think about checking things. Today I ran IPR and ICP.
Old Sep 25, 2010 | 08:32 PM
High Binder
EOT- Oil temp
ECT- Coolant temp
Is that right? are you looking for a spread and if so what's an acceptable spread?
What would a spread out of tolerance indicate?
Old Sep 25, 2010 | 08:47 PM
RedEagle58's Avatar
RedEagle58
EOT- Oil temp
ECT- Coolant temp
That is correct. Yes, keeping an eye on temperature spread of no more than 15 degrees difference between the two. Exceeding that spread more than likely indicates a plugged oil cooler, which could lead to egr cooler problems.
Old Sep 25, 2010 | 09:24 PM
amdriven2liv
Yes, that is my main 2 things to watch. I really watch it while I'm pulling my RV. Would like to get additional gauges for fuel pressure, oil pressure, and EGT's. Those will be next.
From what I have read, here, the 15 degree spread is based a lot on highway speeds unloaded. I have seen 15 degrees spread during my pulling the trailer, but it fluctuates when I crest the hills, and am less concerned as I've learned my motor temps.
2wdDezlX
Jan 16, 2017 08:24 PM
spudlicker
17
Sep 28, 2016 08:36 AM
jrockdiddy
15
Mar 17, 2015 11:05 PM
hwyhogg
Feb 16, 2014 07:40 PM
BrianA
Alabama Chapter
15
May 11, 2009 11:08 PM
