I'm planning a long trip cross country hauling a trailer with my 2001 7.3 with 170K miles. Its been an extremely reliable truck with no major problems so far. Recently replaced the water pump, did the CPS recall thing, and have gone through a couple of alternators, and a gas pedal position sensor. Thats about it.
My question is is there anything I should do to prepare for the trip other than make sure I have fresh oil. Anything I should check, and or replace proactively, that could potentially be a problem at 170K plus miles?
Just trying to avoid being stranded on the side of the road. (I already have a spare CPS and alternator).
I bet you will be fine with what you have done.Throw a selection of metric tools in,fuel filter,gallon of oil,qt of tranny fluid,jumper cables and head out and have a good time
What Barry said, plus Its always good to have a spare CPS just in case.
My recall cps made my truck idle a bit funny.
Also a serpentine belt and breaker bar.
Enjoy the trip.
Same as riverrat said, I made 3500 mile trip in Aug & took about what he said. Pulled a 10k trailer the whole trip & used about 1/2 of the gal of oil I took with me, mines got 183k on it & I believe these things go by ( the longer the stronger ) motto. Good luck
Tell us about your trip you will be taking. If you break something on this trip, someone may be close enough to give you some help.
Thanks for all the responses, guys. I'll make sure I bring everything you recommended.
I'm actuall hauling a boat from eastern Colorado over the Rockies to Parker, AZ, then going on to So Cal, then driving back to Colorado. All over the week of Thanksgiving. Last time I did this trip my alternator went out on I-70 in the middle of Utah and sucked my battery dry. No cell reception. Luckily, I had an extra battery from the boat I put in and it got me almost to Green River where I had to get towed in the rest of the way. Thats a long stretch of nothing out there.........
That's a pretty good haul. I guess you will be leaving the boat in AZ, or are you just taking the boat for a ride?
Drive safe.
Drive safe.
Thanks! Yep, leaving the boat in Az. for the Winter, then I'll go get it in March/April. I did this for years and years when I first got my truck but have not gone for the last several.
I had to replace a previously-fine starter on a similar trip with a similar truck. Fortunately, I had all the tools to do it, but I was glad I brought metric and SAE nutdrivers and a needlenose vise grips, along with a breaker bar, sockets, etc. You can't plan for everything, but you can plan to be prepared for some significant fixes. My starter had shown no signs of wear, which irked me when it stuck in the flywheel while running, in the middle of Iowa. Other than getting boned full list price on a new starter at a dealer, all went well. Also, throw in a hammer in case your starter sticks ;-)
Thanks for any advice.
For 255,000 miles, the one and only time I've been stranded on the side of the road was when the passenger side injector harness came unplugged. I had my 5th wheel trailer in tow and was in the mountains pointing uphill. The engine ran, just couldn't move the trailer even a few feet to get off the interstate.
If you haven't secured your harness with the plastic Ford clips or 2 quarters then you may consider doing that prior to departing. It's just a LOT less nerve racking to work on your truck in the driveway vs the side of the interstate.
If you haven't ever replaced the front hubs, it would be a good time to shoot some grease through the ABS sensor holes. Hubs aren't cheap, and can strand you for a couple of days if you have a failure. Even sealed bearings need greasing once-in-a-while.
Make sure that there is split-loom around the pressure hose adjacent to the driver's front shock tower. It wears through and causes a heckuva leak.
Insure the driver's valve cover harness isn't wearing the insulation off some wires there\ on the bottom side.
Make sure the differential is topped-off with synthetic gear grease, and you have no rear seal leaks.
Just thought I'd check back in and report on my trip. About 2800 miles in all and the truck ran and pulled like a champ. No issues at all whatsoever. I love this truck.
One question for you guys, I have noticed a bit of a "groan" lately. Its been getting more pronounced lately. I notice it a idle and slow speeds, it is intermittent in park with my foot off the brake, and seems to get louder/more consistent (but still intermittent) when I step on the brake and/or turn the wheel.
I'm thinking hydroboost pump or power steering pump but I cannot pinpoint that the noise is coming from either of those, at least as far as I can tell.
I have not noticed any change in the braking or steering.
I did the power sterring transmisson fluid swap before I left but it did not help.
Any suggestions as to what I should check or how to check out the two items above before replacing them?
