Transmission
Old Sep 24, 2010 | 10:10 AM
deano-was-his-name-o's Avatar
Transmission
Hey, The wife called me on her way to work, she said the tranny was shifting super hard. I just drove it last night and it was fine. I just wanted to get a heads up before I can go look at it tonght on my way home. What do you think?
Thank you
Dean
Old Sep 24, 2010 | 11:00 AM
rupejosh's Avatar
rupejosh
the tach sensor could be on its way out putting the tranny into limp mode
Old Sep 24, 2010 | 11:26 AM
Ok. How do I diagnose this. Are there any other symptoms, like that tach not working? Where is this located?
Old Sep 24, 2010 | 11:59 AM
Lazy K's Avatar
Lazy K
The tach sensor is on the injector pump drive gear housing beside the engine oil filler. Looks like a big nut with two wires out of it. If it is bad the tach will be irratic or not working.
However I would think there will be trouble codes stored so may be a good first step to check for them. That is assuming there is nothing obvious like the tach or speedo not working properly.
Old Sep 24, 2010 | 12:21 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
The Tach pickup is on the Injection Pump Gear cover ... Two wires, takes a 1" wrench.
Typically the wires crack as they exit the pickup allowing moister in and ruining the pickup.
You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
-Enjoy
fh : )_~
Old Sep 24, 2010 | 12:22 PM
Festus Hagen
Methanoholic
It can be tested: Tach Sensor Testing
-Enjoy
fh : )_~
Old Sep 24, 2010 | 12:40 PM
I did notice the spedo jumped 2 or 3 mph yesterday when I was taking off from a stoplight. It only did it once and that was the first time. I just talked to the wife and she said it also shifted hard slowing down. I will check the wires thank you for your help. You are making me feel better about a tranny rebuild. It was rebuilt by the guy I got it from and it has about 70,000 miles on the rebuild. I will check the wires when I get home tonight. The tack was working sweet though. I don't know about today. Someone said there would be trouble codes, where do I get thoes as it is an early model (no obdII port)
Old Sep 24, 2010 | 12:49 PM
The link you gave me sounds like what is going on. Thank you again and I will check when I get home tonight
Old Sep 24, 2010 | 01:51 PM
Festus Hagen
Methanoholic
If your Speedo is acting up, it may be the VSS in the rear end ...
Either will confuse the E4OD ...
You must get this fixed ASAP, It will damage the transmission!
Is the OD light flashing???
-Enjoy
fh : )_~
Old Sep 24, 2010 | 02:27 PM
Lazy K's Avatar
Lazy K
Ford Fuel Injection How To Run a Self-Test Here is how to check for trouble codes. If you don`t have a check engine light (which you may not being a diesel) then wire in a meter or small test light as described. Also ignore the part about KOER and with the KOEO floor the gas pedal during the test otherwise you could get a false TPS code.
You could also get an OBD1 code reader for around $30.00which makes life easier.
Old Sep 24, 2010 | 03:42 PM
I had my wife's boss take it arround the block to see if he coguld give me any more info. The truck drove like normal. So I am coming to the conclusion that it is that tach sensor. I hate waiting to get off work lol.
Old Sep 24, 2010 | 08:58 PM
Ok the wires are twisted up pritty bad. To test it- take it clear out of the truck? And plug the voltmeter in the plug end? And what should it read?
Old Sep 24, 2010 | 10:52 PM
Festus Hagen
Methanoholic
Well, It appears I provided the testing info twice (posts #5 & 6), nearly identical posts, pretty sure I only posted the one with the link ... I dunno know!
Pretty sure I can't type that fast either!
-Enjoy
fh : )_~
Old Sep 27, 2010 | 12:39 PM
I took out the sensor and there was some wires showing, but very small, I almost missed it. I orderd the part from ford and it will be in on tuesday. I hope it is the problem
Old Oct 17, 2010 | 03:03 PM
Ok truck was running fine with the new sensor. Went down a 6 mile trail in 1st gear. Looked down the overdrive light was flashing. I put it from 1st to drive and it shifted hard. Turned off the truck then back on. No flashing and shifts fine. What's your next guess?
