Directionals
Old Feb 21, 2003 | 07:37 AM
AgentG's Avatar
AgentG
Question Directionals
My left side just went dead. I checked the lights both front and rear and they were okay. I think it might be the switch on the column. Anybody have a similiar experience or could put some light (no pun) on the subject? Is the instrument bulb part o fthe circuit?
Thanks
Old Feb 21, 2003 | 09:44 PM
Racerguy's Avatar
Racerguy
Directionals
I've seen this before and it was the signal light switch on the column. It needed to be replaced. Remove the upper and lover covers on the column to access it. You have to unscrew the tilt lever, remove the ignition lock cylinder by turning the key to the run position then poking a thin screwdriver or metal rid into the hole in the lower cover to push in the pin in the cylinder, then remove the screws that hold the covers on and remove the covers.
The switch is held to the column with 2 torx head (usually) screws. Once it is loose you can unplug the wiring to it. Reassemble in reverse order
2004f250superduty
Nov 4, 2013 11:40 AM
abyars111
Nov 12, 2012 09:18 AM
armour01
2004 - 2008 F150
Oct 16, 2012 02:11 AM
blackford97
Sep 5, 2011 10:28 PM
skip hatfield
2004 - 2008 F150
Mar 17, 2010 02:02 AM
