Is this fixable?
Old Sep 23, 2010 | 11:49 PM
Rylan's Avatar
Rylan
Is this fixable?
my Offy Dual port 360 intake has a "flange"? broken off.
Is it fixable at machine shop? and how much would it cost?
Old Sep 24, 2010 | 12:22 AM
Harte3's Avatar
Harte3
If your machine does welding, probably yes. Get an estimate from them on the cost and then you will know for sure.
Old Sep 24, 2010 | 09:47 AM
AbandonedBronco's Avatar
AbandonedBronco
Hey Rylan,
Do you have the tab that was broken off?
Seek out a machine shop that specializes in aluminum welding, since it takes a special skill.
They'll need to re-attach the broken tab, or weld on a new one. Resurface the underside so that the entire thing is planed and sits flush, and surface the top side as well (the one where the bolt head sits). They'll also need to make sure the tab is the same thickness as the rest, or the bolt sitting on it will torque and not give a good seal.
It's fixable, but you need someone who knows what they're doing.
Mine was cracked (not broken off). The guy charged me $60 to straighten the tab, weld it on, enlarge another tab that had some of it missing, and then resurface the whole thing. If they start getting up into the $100 range to fix it, you may be better off just seeking out another used one.
GaMachinist
Mar 27, 2014 10:30 PM
lavatan
Jan 14, 2012 06:04 AM
bassproguy07
Paint & Bodywork
Apr 13, 2006 11:05 PM
chrison600
Jul 7, 2003 10:27 PM
