OK well just pulled the turbo looks real good going to clean up. The intake on the other hand did not look that good it had a lot of sutt build up and it was real gummy fealing. Not to sure what it may be from but my thoughts are that the egr cooler failed, so i will be replacing that also but i need to know excatly where the oil cooler is located at or any other advice. Oh yea please help me decide which to go with the eger delete or cooler replacement. thank in advance
Well took the radiator and intake to get cleaned today. They said the radiator was over 85% clogged which it should not done the home flushes but guess didnt work all that good, just waiting for egr delete and new oil cooler then back together hopefully all will work
I think I have only heard of one other person having a plugged radiator.
I had some white residue on the crimped seams around my radiator. Why do they use the plastic caps on them. I just bought a brand new radiator. It seems to run cooler. I have not towed with it so we will see.
