"The cure"
Old Sep 23, 2010 | 08:36 PM
BullyDogJason's Avatar
BullyDogJason
Former Vendor
I know we make a shift kit for the e40d.
Old Sep 23, 2010 | 08:38 PM
Action4478's Avatar
Action4478
Originally Posted by chicagodragon
is "the cure" a program
It changes the PCM TC program ....
Old Sep 23, 2010 | 08:40 PM
chicagodragon's Avatar
chicagodragon
does it go on an aftermarket chip, or is it flashed into the pcm?
Old Sep 23, 2010 | 08:44 PM
Action4478's Avatar
Action4478
It is a totally separate add on,,,,, changes the signal from the PCM to the TC ,,makes it faster . Mileage is better , performance is better , less wear in the TC ...Trans will last longer ...
Old Sep 23, 2010 | 08:45 PM
F350-6's Avatar
F350-6
As in springs and spacers to be installed in the main or accumulator valve body, or the electrical type?
Old Sep 23, 2010 | 08:46 PM
chicagodragon
do you have a site link, or do i have to email sombody?
Old Sep 23, 2010 | 08:48 PM
Action4478's Avatar
Action4478
..........shiftsolutions@yahoo.com.............
Old Sep 23, 2010 | 09:34 PM
C350CREW's Avatar
C350CREW
Has anyone gotten an answer on how to install the Cure??
Old Sep 24, 2010 | 07:49 AM
Action4478's Avatar
Action4478
It is a separate unit , switch 4 wires leading to the trans , the cure goes in line .It takes about 20 minutes to install ...Name:  Cure mounting.jpg
Old Sep 24, 2010 | 09:21 AM
kawa's Avatar
kawa
Talking
"Madvan" sells "The Cure" Contact him for details and cost.
Rog
Old Sep 24, 2010 | 04:53 PM
tjbeggs's Avatar
tjbeggs
The Cure!
Good stuff. Its a little tricky to install but it you remove the wiring harness pig tail that it is wired into its much easier! The pigtail has another plug that is on top of the transmission and then you can get the foot long connector out on the bench to repin it. But if you leave the pigtail on the truck its not very easy.
But once its on you will enjoy The Cure! No other product out there like it. or that will deliver these results
Mtnhermit
Apr 30, 2016 12:57 AM
Schmitty
Jul 1, 2004 11:45 AM
