Odd air leaking noise
Old Sep 22, 2010 | 09:42 PM
rwchugger's Avatar
rwchugger
If I weren't already bald this would cause me to pull all my hair out. I have an 02 EXCURSION V10 Limited 4x4 104k. I have what sounds like an air leaking noise only when the vehicle is moving, in 2wd, under load, approx 1700-2000 rpm. The noise is similar to a schu schu schu schu etc. and leaves when speed and rpms leave that range. This does not occur in park while revving and also cannot be heard while wheels are chalked and brake is applied, in D, rpms in range. The noise is not metallic and sounds like a loud vacuum leak but is not constant when driving and also has no felt effects on driving whatsoever. I have inspected the pcv and it seems to be operational but will be replaced. Recently it has been suggested that it may be a vacuum issue with the Temp. Accuator door. Any suggestions or insight would be greatly appreciated. I read the forum all the time but this is my first "cry for help." Thanks for reading
Old Sep 22, 2010 | 10:08 PM
jh818's Avatar
jh818
I'm thinking it's wind noise or maybe your tires out of balance? Sounds like at that rpm, there is a frequency which resonates just right. Maybe a heat shield? Can't tell without hearing it. Is it a fast schu schu schu?
Old Sep 22, 2010 | 10:45 PM
rwchugger's Avatar
rwchugger
Tires are less than a yr old and i have had a recent alignment. The "schu-schu" noise is fast, like 3-4 per sec. Also, i've removed the heat shields from the y-pipe as the welds had broken almost free. Tire place did not mention the issue nor try to get more $ to investigate. Thx for reading and replying. Ever heard of the Temp accuator door?
Old Sep 22, 2010 | 10:57 PM
jh818's Avatar
jh818
What's a temp actuator door?
Old Sep 23, 2010 | 05:31 AM
rdct's Avatar
rdct
I have a wind noise too recently. Haven't investigated thoroughly yet but have been paying attention to consistency.
I wouldn't describe my sound like yours, was first thinking my roof racks were whistling; moved them to the back, didn't make an ounce of difference, and anyway they never made the noise before in their original position.
Started thinking I had a window not shutting completely but that was easily taken out of equation.
The one thing I can tell for sure is that it is consistent with the heater blower. Turn the fan on higher, the sound increases - so the blend door sounds like a good theory. It was actually my next spot to check before I saw your post.
My truck sat for quite a few weeks without driving, didn't have the noise before it sat. Seems like a vacuum noise the more I listen but doesn't change with rpm - so that makes me believe it down-stream, like heater controls. I'll let you know what I find unless you find yours first.
Old Sep 23, 2010 | 08:12 AM
rwchugger's Avatar
rwchugger
My noise doesn't really present as a "wind" type noise. I have not messed with the different temp settings as it does it when the temp controls are off and the windows are down. According to a co-worker, there is a vacuum accuated door that regulates the air from outside, mixing with the cooler air from the AC, to set the thermostat temp when using AC. His theory is that some where on the assembly there is a vacuum leak or line off that is allowing that door to "flutter" air when a certain rpm is reached under load/travel due to increased vibration. Its the wife's rig so it'll be a day or so before i can tear into it further. thanks though
Old Sep 23, 2010 | 11:28 AM
rdct's Avatar
rdct
On the way in this morning; heater controls off, windows up - no noise until I hit about 30mph.
Switch to any position on the controls; noise changes slightly.
I'll be under the dash this weekend.
Old Sep 27, 2010 | 10:05 AM
fomoco6.8's Avatar
fomoco6.8
Boy, this sounds very similiar to the dreaded exhaust "flutter" to me. You may want to search the forum for other members discriptions of their underside noises. You even used the "f"-word in your last post! Haha. It's also right in the rpm zone that mine was.
Hope this helps...
Old Sep 27, 2010 | 10:52 AM
RobRoss's Avatar
RobRoss
Did you change your air inlet or is it all stock (intake, filter, hoses etc...)?
Old Sep 27, 2010 | 11:16 AM
rdct's Avatar
rdct
I couldn't find my noise under the dash. All heater positions seem to be working properly.
Going to get the boy to move around the cabin (on unpopulated roads of course) and see if he can pin point it.
Old Sep 28, 2010 | 10:44 PM
jimzigg's Avatar
jimzigg
i have this exact issue and wanted to post it earlier. i couldnt really think of how describe the sound and circumstance but its pretty much dead on.........
Old Oct 5, 2010 | 10:58 PM
rwchugger's Avatar
rwchugger
Thanks
After the posts here i did some more research and took it to a trusted coworker that still works for Ford and he said it seemed to be similar to the flutter issues that i've read about. Since i have the necked down y pipe, i'm gonna start by replacing that 1st and let ya know. Probably be a few weeks. thx all
Old Oct 12, 2011 | 08:06 PM
Fordman96's Avatar
Fordman96
I have heard the similar noise on my 02' limited excursion. 150k miles on it. When i accelerate at times i hear an air leak. Seems to be coming from the front left of the truck it almost sounds like a compressor being drained when the air is let out. Cant pin point it and have been at quite a while. Ill keep looking though and let you guys know what i find.
Old Oct 12, 2011 | 08:10 PM
RobRoss's Avatar
RobRoss
Any purge solenoids on that side under the hood?
Old Oct 12, 2011 | 08:29 PM
rwchugger's Avatar
rwchugger
Air leaking noise
I found it in another forum page. Laying under the rig, in the middle, on the housing where the engine and transmission meet, there are 2 "shields" in the front on the bell housing. 1 is heavy steel bolted tightly, the other is almost like sheet metal and only has 2 bolts on both sides. When the RPMs reach the range of say 1700-2100, it vibrates the thinner metal one causing the "air leaking" noise I described. When I read the other post I thought no way it could be that easy. I wedged a small piece of rubber, temporarily, behind it, and could not get the rig to make the noise. I then simply removed the thin metal shield, put some rtv gasket on it, waiting til it glazed and reistalled. No noise for the last 6 months. I was careful not to completely seal the entire shield as there is a dimple that appeared to be made for moisture to drain???? Regardless, that fixed my leak and severe headaches.
