Opinions please..
Old Sep 22, 2010 | 01:26 PM
53 Meadow Green's Avatar
53 Meadow Green
Opinions please..
My steering wheel has two cracks. And, the plastic anniversary horn button looks "used". Otherwise my truck is beautifully restored. I almost bought a new steering wheel and horn button but at the last minute decided to re-think this.
Is the original wheel even if cracked and scratched horn button more valuable, cooler, nostalgic, etc than shiney new repros on an otherwise older concourse restoration (I drive it now)?
Old Sep 22, 2010 | 01:54 PM
lvin4jc's Avatar
lvin4jc
IMHO, I would replace it. The fact that you started to order a new one tells me that you see it doesn't fit with the quality of the rest of the truck. I'm going to replace mine but it has many more than 2 cracks in it and when my truck is "done" it won't look nearly as nice as yours. Good luck!
Old Sep 22, 2010 | 04:59 PM
ZOOT's Avatar
ZOOT
The cracks can be fixed. The button sounds like it might add a vintage flavor to the interior.
Old Sep 22, 2010 | 05:29 PM
theGman's Avatar
theGman
Looks good with the new wheel and button; like a shiny pair of shoes with an old suit.
Old Sep 22, 2010 | 06:34 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
and as an added bonus you can glue a magnet to the back of the old horn button and have a great fridge magnet
Old Sep 22, 2010 | 06:52 PM
Julies Cool F1's Avatar
Julies Cool F1
Why not buy a new after market wheel and Anniversary Horn Button and use those for everyday, and then wrap up the originals and store them - in case you want to sell the truck and have the originals.
Horn Buttons are available at C&G Ford Parts (so are the steering wheels). Theyre expensive (@ $75) but it's the centerpiece of your cab.
https://secure435.hostgator.com/~dlv...g=45&t=330&tn=
Old Sep 22, 2010 | 07:06 PM
Rust_Rat's Avatar
Rust_Rat
Hmm, Can you please post an image of your steering wheel? My beastie actually came with three wheels, sans buttons sadly, but if it matches, we may be able to work something out.
Old Sep 22, 2010 | 08:42 PM
green53's Avatar
green53
You can fix your wheel, I did. Take a dremmel and open the cracks in the wheel, this takes any loose pieces off and gives a good 'tooth' for the next step. I use J.B. Weld and fill just below the original level, don't be conserned about not enough all at one time. I applied 3-4 coats with the dremmel in between. The last filler I used was the fibregas re-inforced bondo, using files, broken hack saw blades that I took the set off with a bench grinder and finally hardwood shaped like the 'lines' to make everything look good. Because the wheel is exposed to UV, you need to finish with 2 component urethane. Also, I bought some green liquid fine metal and plastic polish and have used this on all my original plastic parts, shift ****, switch *****, parking light lenses, this will work out scratches and cloudyness on your horn and all the rest of your plastics. I just use rags and rub by hand. You should see the front parking lights I did, beautiful. Hope this helps.
Old Sep 22, 2010 | 09:14 PM
fifty-two_f1's Avatar
fifty-two_f1
I have also done the JB weld restoration, It works really well and saves money.
Old Sep 22, 2010 | 09:46 PM
53 Meadow Green
You guys are great!
I want to keep the original wheel and horn button as long as I have the truck. Couldn't ever part with it...
The JB Weld trick does work. I did it on my 66 GTO sport wheel.
I kind of like the vintage charm of the original but it does stand out to me as "unfinished". Then again, it works and makes the truck look more like a nicely shined up survivor...it isn't a money issue. Probably oughtta pull the trigger and get new.
Old Sep 23, 2010 | 07:05 AM
cruisetopdown's Avatar
cruisetopdown
Sounds like you need a new wheel and button.... my advice would be to go out and find a suitable truck for that nostalgic wheel
Old Sep 23, 2010 | 09:01 AM
Doc's Avatar
Doc
My dad has a near mint 1950 ford coupe. It is very nice. The orginal steering wheel is still there. It has 2 cracks/separations where you can see all the way down to the steel ring. I offered to replace it. He flatly refused. Now that I've thought about it, I think that adds originality to a restored car or truck. But that's my opinion. A picture of this steering wheel would probably help us give you a better opinion.
Old Sep 23, 2010 | 09:06 AM
53 Meadow Green
Mountaindoc. You're pulling on my heart strings. The cracks are small and the horn button is scratched. There are some chips on the wheel where someone has pry'd off the horn button. Not horrible but ...
Old Sep 23, 2010 | 09:14 AM
Doc's Avatar
Doc
Do you have it on the internet anywhere? Like shutterbug, facebook, a gallery, or anything? We can take it from there if you'll give us the actual internet address (URL) to the picture.
Old Sep 23, 2010 | 09:15 AM
arctic y block's Avatar
arctic y block
I think ya need 25 posts or more before ya can put up pic's and a few other things.
