Sponsored by: Real Truck
timming trouble's
Old Feb 20, 2003 | 09:19 PM
jhreddell_68's Avatar
jhreddell_68
Question timming trouble's
I have a 93 ford 1 ton with a 460 that run's good but i can't set the timming with the spout conn. un pluged, it run's rough and doesn't won't to idle'but when you plug it in it run's fine. I've hooked my scanner up and run test's but everthing shows to be working and there is no code's
Old Feb 20, 2003 | 09:38 PM
NoMo's Avatar
NoMo
timming trouble's
Not trying to be a smart-@$$, but if the truck runs fine, why are you wanting to adjust the timing? Is/was there another problem with the truck?
In addition to asking here, you might also want to ask down in the "big block" forum. Guys down there don't seem to make it up here a lot... or at least they don't post here much.
Old Feb 21, 2003 | 01:45 PM
Grey Ford's Avatar
Grey Ford
timming trouble's
Sounds like the timing is retarded too much. Removing the SPOUT will reduce the idle speed, but the engine should continue to run.
Try this: loosen the dist. hold down clamp slightly while the engine is running. Turn the dist. to advance the timing just enough to increase the engine speed slightly, then tighten the clamp.
Now remove the SPOUT and set the timing to spec. or whatever turns you on. Re-install SPOUT and all should be well.
Old Feb 24, 2003 | 10:54 AM
jhreddell_68
timming trouble's
I have the dist. adv. now. thats how it running,but still when you un plug the spout cont. it goes nut's. I can get by with it but would like to fix it right. thank,s for the reply.:
Tim Young
30
Mar 8, 2011 02:31 PM
AbadDriver
1978 - 1996 Big Bronco
Oct 12, 2003 01:08 PM
AbadDriver
Bronco II
May 14, 2003 02:30 PM
tim330i
20
Feb 23, 2003 01:41 PM
RJKobbeman
17
Mar 30, 2002 12:41 AM
