Can someone help?
Old Feb 20, 2003 | 07:22 PM
redranger90's Avatar
redranger90
Can someone help?
I have been put on a quest to find a triangulator. I know what its for, but all i can find are software programs to do it. What i'm looking for is apparently the old kind that was something like a slide rule. I have searched google, msn, amazon and ebay in hopes of at least getting a picture of what this thing looks like. I have a patent number for it if that would help. I dont know if its possible to search by patent number. any possible help is greatly appreciated.....
Old Feb 20, 2003 | 07:38 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Can someone help?
It sounds like what you're describing is an E6B, airman's flight calculator. It works like a slide rule to solve problems for ground speed, fuel use and stuff like that. On the back side is a compass bezel and grid to triangulate course correction angles for wind speed/direction problems.
You can get an E6B at an airport flight center that sells sectional charts, books and other supplies for pilots and student pilots.
E6B link
Scott
Old Feb 20, 2003 | 08:28 PM
redranger90
Can someone help?
Thanks! the CC has a pilot program now I'll check there. If thats not it or wont work well then I'm still clueless.
Edit: well i just did a patent search and found a diagram of it and its something different, it actually looks like a slide card. I'm sure i wont find an original one as it was patented in 1939. but surely I should be able to find one somewhere I would think....any one have any ideas?
Old Feb 20, 2003 | 09:49 PM
horsepuller
FTE Emeritus
Can someone help?
Okay, now you got me really curious.
Would you post back with the link you found?
And what are you gonna use it for?
Scott
Old Feb 20, 2003 | 11:23 PM
redranger90
Can someone help?
This is the link I needed to be able to view the information. Its only free for 5 days.
to view patent info
This is where i got the info. The patent number is 2166372
patent search
Its used in some engineering classes I'm told (I havent gotten that high yet). For now I just want to "play" with it until I need it (sorry I'm a geek). If you put in certain info about an angle it will give you the formula(s) to figure out the missing info. Maybe I'll see what else I can find on the soft ware versions. They look like more fun.
Marti
Old Feb 20, 2003 | 11:40 PM
horsepuller
FTE Emeritus
Can someone help?
Thanks for the link. Guess I was way off.
Good luck with your search though.
Scott
Old Feb 21, 2003 | 02:07 PM
winfordr's Avatar
winfordr
Can someone help?
Ever heard of aircraft spruce and company?
They have all kinds of aviation stuff.
Check out: http://www.aircraftspruce.com/catmai...st=cathome.php
WilliesSD250
May 13, 2016 05:46 PM
jake00
Jul 15, 2009 09:29 PM
captain p4
23
Oct 12, 2006 08:58 PM
MatthewC
Nov 21, 2004 10:20 AM
RICE H8R
Sep 13, 2004 07:12 PM
