Sponsored by: Real Truck
Maybe I am missing something?
Old Sep 21, 2010 | 04:39 PM
Great Danes's Avatar
Great Danes
Question Maybe I am missing something?
Hey all!
I am currently driving an F150, but looking to upgrade to a 2011 SD in the near future to pull our trailer with a little less effort.
I am definitely going with the PSD but I can't seem to find any major differences between the F250 and the F350 (SRW) in terms of towing capacity or payload.
Can someone please summarize the major differences for me as I seem to be missing something here.
Old Sep 21, 2010 | 05:02 PM
Futuresweets-10's Avatar
Futuresweets-10
People will argue this point, but in my opinion there are three differences.... Price tag, badges, and the 350 sits 2in higher.
Old Sep 21, 2010 | 05:36 PM
ChargersFanInCO's Avatar
ChargersFanInCO
And in Colorado, about $400.00 more for tags.
Old Sep 21, 2010 | 05:38 PM
redford's Avatar
redford
FTE Leadership Emeritus
There is no difference in the towing capacity of an F-250 and an F-350 Single Rear Wheel.
An F-350 has a higher cargo carrying capacity, but is not rated to tow any more.
Old Sep 21, 2010 | 05:45 PM
ak-angler's Avatar
ak-angler
And I believe the greater carrying capacity comes from the taller blocks allowing more spring flex before bottoming out.
Old Sep 21, 2010 | 07:27 PM
scububbs's Avatar
scububbs
I just dealt with the same issue two weeks ago. Our new travel trailer was too much for the '07 F150 so I began researching the Super Duties. Since there was not any real difference in towing capacities I settled on the F250. Towing is my primary reason for buying a new truck, since I can always hitch up the utility trailer if I need more payload. Also went with the 6.2L gas engine because the deisel doesn't increase towing capacity in the F250. This weekend will be the first tow with the new truck, and I'm looking forward to finding out how much difference there will be.
Great Danes
Thanks for the replies. So, basically if I don't need physical carrying capacity, I might as well save a few bucks and get the F250. Just wanted to make sure I wasn't missing anything obvious!
Still gonna get the PSD for the obvious towing benefits!
Old Sep 21, 2010 | 09:21 PM
sdetweil's Avatar
sdetweil
right.. in many states the registration limits are 10,000 lbs, or above 10,000.. so the 250 and 350 both can come rated at only 10,000lbs,
even tho the equipment supports more.. the door tag wins for registration purposes..
Sam
Old Sep 22, 2010 | 06:21 AM
Great Danes
OK... so when some people on here indicate they are towing 14k or 16k 5ers are they technically overloaded? The specs state the trucks are only rated for 12.5k? Are the older trucks rated higher than the 2011?
Sorry for all the questions, I am a bit of a noob when it comes to towing and loading.
Old Sep 22, 2010 | 06:59 AM
redford's Avatar
redford
Perhaps. Some vehicles are rated at well over 15k towing 5th wheel, but some guys do run over the recommended towing weight.
Old Sep 22, 2010 | 07:14 AM
sdetweil's Avatar
sdetweil
there is conventional (bumper) pull and 5th wheel.. the 12.5 is bumper pull, and its because of the hitch.. you can get 18k hitches.
5th wheel is 15700-15800 depending on the GCWR for the 250..
see here 2011 Ford Super Duty | View Towing Specifications | FordVehicles.com
for my 08 is the same
http://www.fordvehicles.com/assets/p...TTgdeMay07.pdf
Sam
Old Sep 22, 2010 | 10:20 AM
Great Danes
Thanks for the clarifications and the links! I am starting to figure this out in order to make the right decision on my new truck.
