Update
Old Sep 21, 2010 | 03:00 PM
mabc926's Avatar
mabc926
Update
I did a little "test" to see if my oil cooler was bad or not before I rebuilt it.
So what I did was drained all my oil, and drained my coolant, and let the truck sit for a few days to get all the oil out of the oil pan,
then i filled my rad up with water this time and sat a bucket under the oil pan drain,
I let it sit for two days and when I went back to check on it not a drop of water was in the bucket and my rad was still full.
This makes me think that my oil cooler is still ok and all the coolant in the oil was from the bad headgaskets, (or a crack in the block)
Anyways I'm just going to fill her up with oil and see what happens.
Old Sep 21, 2010 | 04:56 PM
rodneywar's Avatar
rodneywar
u should try pressurizing the coolant system to simulate normal conditions to try to fing the leak
Old Sep 21, 2010 | 05:03 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Without pressure that was pointless ...
As stated you need to pressurize the cooling system.
However even pressurizing the cooling system likely won't produce results, The water would have to travel through the oil galleries to escape.
-Enjoy
fh : )_~
Old Sep 21, 2010 | 05:22 PM
mabc926's Avatar
mabc926
Well crap..........I'm just not looking forward to doing that oil cooler........
Old Sep 21, 2010 | 05:44 PM
oreocreaming's Avatar
oreocreaming
its not so bad man. once you do it once, you'll see its easy.
Old Sep 21, 2010 | 05:54 PM
mabc926's Avatar
mabc926
Yeah, you're right.......I'll just get my *** to work and do it
