heads and header compatibility
Old Feb 20, 2003 | 06:17 PM
scottjohn's Avatar
scottjohn
what headers are required (if any) on a 351W with gt-40p heads. I heard that they require special ones when using the heads
Old Feb 24, 2003 | 11:47 AM
HotWhlz85's Avatar
HotWhlz85
Hey Scott,
Due to the angle of the spark plugs in the Gt-40p heads, there are some header issues to keep in mind. Regular spark plugs won't work but there are shorter plugs available that I have heard will work with regular headers. I've also been told of people putting a ding in their headers to clear the plugs. There are companies that make headers especially for this head but they are expensive. Most people I've heard use the manifolds from an Explorer to get around the problem.
Old Feb 24, 2003 | 01:15 PM
swirk's Avatar
swirk
Same answer here. Ding some of the primaries and use the shorter plugs from a '97 Mercury Mountaineer or '97 Ford Explorer. I think that they are motorcraft number AWSF32-C. They are shorter plugs. You should also use 90 degree angle plug wires. You can not use the Mountaineer or Explorer wires, they use coil packs.
There is some info on the bottom of this page.
http://www.geocities.com/MotorCity/Pit/5755/gt40p.html
Old Mar 12, 2003 | 10:11 PM
w76ford's Avatar
w76ford
summit has mustang headers that are designed to fit the gt-40p heads. the part number is FMS-M-9430-P50 for 239.95 or FMS-M-9430-51 for 299.95.
wyazel1
Oct 2, 2015 06:24 PM
Encho
Aug 20, 2014 02:05 PM
mooray
Exhaust Systems
Aug 29, 2010 02:04 PM
J1MMY
34
Jun 28, 2010 05:13 AM
Flexfuel-Dave
Engine Swaps
Jun 11, 2005 11:20 AM
