Speed sensor
Old Sep 20, 2010 | 07:18 PM
LonnieD's Avatar
LonnieD
Speed sensor
What would a bad speed sensor do? It's on my 93 F350 Turbo...tarnny is re-built and she likes to go in and out of gears when crusing at 40 to 55 MPH..could it be the speed sensor and if so is it hard to replace. I resad it's loacted on top os the rear-end but os it just a unscrew and repace, then plug in wires situation?
Old Sep 21, 2010 | 07:08 AM
subford's Avatar
subford
If your speedometer is steady and working right then speed sensor and its wiring to the PSOM are OK.
Check your MLPS (TR sensor) with a ohm meter and the wheels blocked.
Old Sep 22, 2010 | 01:30 AM
LonnieD's Avatar
LonnieD
aaa whelp
Geesh that is a little above my head...I assume ford could check this as well right? Where is this sensor, I would have no idea, what does it do?
Old Sep 22, 2010 | 05:52 AM
subford's Avatar
subford
Yes FORD can check it with a Transmission tester.
Description: The Manual Lever Position Sensor (MLPS) or Transmission Range (TR) sends a signal to the PCM. This indicates the position of the shift lever (P, R, N, (D), 2 or 1). The MLPS is located on the outside of the transmission at the manual lever.
Old Sep 22, 2010 | 10:22 AM
LonnieD's Avatar
LonnieD
problem
Would that tell the transmission to change into OD or out of OD based upon rpms?...mine shifts like that at certain speeds (40-55)..
Old Sep 22, 2010 | 12:39 PM
subford's Avatar
subford
The computer uses a number of sensors to shift in and out of OD.
It uses the information from the TP, TR, PIP sensors plus the PSOM & TC switch to go into OD and it uses the same sensor plus the BOO switch to go out of OD.
TP: Throttle Position.
TR: Transmission Range.
TC: Transmission Control Switch.
PIP: Profile Ignition Pickup.
PSOM: Programmable Speedometer/Odometer Module.
BOO: Brake On/Off.
Old Sep 22, 2010 | 01:18 PM
LonnieD's Avatar
LonnieD
Crap that's a lot for me to pay for some wrench bender to look at...ops gotta be nice well maybe they can find the right one quickly...just put in that rebuilt tranny..
1972RedNeck
Dec 14, 2012 07:18 PM
Ken_C
Nov 22, 2012 11:52 AM
desertt5
Sep 27, 2010 10:17 PM
4x4_EB_Explorer
Apr 4, 2002 01:58 PM
