Intermittent 460 engine clicking
Old Sep 20, 2010 | 03:04 PM
earthkwake's Avatar
earthkwake
I just purchased what I refer to as an "old school" F350 Crew cab 4x4 long bed. Didnt know alot about the history of the truck other than the fact it looked good and has 140k miles. Started going through the truck with an engine coolant flush, oil change, new plugs, wires, cap/rotor, injector cleaning. Have ordered new suspension/steering bushings. Question is, I get a clicking noise in the engine that is relative to rpm. It is there for about 2 or three minutes then goes away for 10 minutes or so and then returns. Is it worn lifters? Someone please point me in the right direction. Thanks.
Old Sep 20, 2010 | 03:09 PM
jokerforever's Avatar
jokerforever
Could be lifters
Could be rockers
Could be an exhaust leak
Old Sep 21, 2010 | 12:46 PM
jmoon93's Avatar
jmoon93
Being that it comes and goes, check oil pressure when clicking bigins. If all is good with that, than the other option is that the lifters are sticking. Heres an old time remedy that always worked for me. Add a quart of tranny fluid to your motor oil, but dont over fill. Let the truck warm up, and run it. If stuck lifters are the case, than this should quiet them down and loosen them up. Watch your oil guage during clicking and see if pressure goes up and down, if so than you may need a new oil pump.
Old Sep 21, 2010 | 01:30 PM
earthkwake's Avatar
earthkwake
Re....Tranny fluid
I dont notice any change in oil pressure when the clicking starts. I will try the tranny fluid approach. Thanks for the tip.............
Tavin_1987
Oct 26, 2015 07:51 AM
Kenpc
Escape & Escape Hybrid
Apr 28, 2015 02:34 PM
jamesaero
Jan 14, 2015 09:29 AM
offroad_4life
Apr 27, 2014 08:15 AM
shadetree55
Mar 30, 2014 06:36 PM
