The last thread I tried said that these are swappable. but There are two offered for the F350 and I need to get the right one. the only difference I could make out on the 2 options for the 75 F350 4x4 were:
with cruise control (in which the push rod was different)
w/o cruise control (in which it looked the same)
I dont have cruise control so I think Ive found a winner? just looking for some confirmation!
This is going to be one of those things you just dive into. I don't think anyone can say with any degree of certainty what you will run into. You have the older pedal linkage style, not the straight through rod like a '78-'79 has. There were more than a few pedals made from '73-'77. Worst case you will have to find a older 350 in a junk yard which should have been done first so you would have a core to turn in, or maby modify your pedal if it comes to that. I put one in my '79 but it's all different so I can't say for sure but get the one without the cruise. Let us know how you make out, this is always a gray area in these trucks.
