Which rims will fit
Old Sep 20, 2010 | 11:18 AM
cowboy_up_07's Avatar
cowboy_up_07
Which rims will fit
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Will any of these rims fit my 97 Ford F-250 HD 8 lug 4x4 its the 92-96 ford body style. 2000-05 FORD EXCURSION, '1999-04 F250SD, AND '1999-04 F350SD.
I like the looks of the excursion rims better than the aluminum ones on my truck and I believe the excursion rims are a little wider.
Old Sep 20, 2010 | 12:41 PM
CJM8515's Avatar
CJM8515
Different bolt pattern, wont fit.
Old Sep 20, 2010 | 01:30 PM
jokerforever's Avatar
jokerforever
And the Excursion rims aren't wider. If you want anything wider than 7" you have to go to the aftermarket.
BTW you have the old 8 lug pattern that was used by Ford from, I think, the early 60s until the 97 250HD/350s. It is still used by Dodge and GM also but their hubs are a little smaller than ours.
Old Sep 20, 2010 | 04:14 PM
cowboy_up_07
gotcha thanks for the info good thing i didn't buy those rims.
Old Sep 20, 2010 | 08:36 PM
TexasGuy001's Avatar
TexasGuy001
Actually some of the fatcory wheels are 7.5 inches wide.
Old Sep 20, 2010 | 10:49 PM
cowboy_up_07
thought I read that the excursion rims were wider. they came stock with 265/75R16 tires on them
Old Sep 21, 2010 | 08:53 AM
jokerforever
Maybe...
I know the half tons that came with 17s had 7.5" rims. I'm not sure about the 17s and 18s from the larger trucks. But I've never seen a Ford factory 16 any wider than 7". I'd like to find some though. Do know where I can find some or at least know the model.
BDB513
Jul 21, 2014 04:38 PM
JPs2003
28
Mar 5, 2012 10:15 AM
hanke777
1978 - 1996 Big Bronco
24
Mar 1, 2011 03:07 AM
nepatriots
Escape & Escape Hybrid
Oct 29, 2010 11:19 PM
mvedepo
6.7L Power Stroke Diesel
Oct 5, 2010 11:42 PM
