Modular V10 (6.8l)
Blown plug
Old Sep 19, 2010 | 06:51 PM
willtim1234's Avatar
willtim1234
Blown plug
What are the symptoms of a blown plug?Thanks
Old Sep 19, 2010 | 10:40 PM
Moto Mel's Avatar
Moto Mel
A serious miss and a loss of power as well as a lot of noise.
Old Sep 20, 2010 | 01:15 PM
bakon's Avatar
bakon
A loud bang and then a loud exhaust leak. Its the gases coming out of the hole. Look for a COP which is popped up.
Old Sep 20, 2010 | 05:21 PM
willtim1234
Thank you for the replies.I don't think I have a blown spark plug.I have rough idle and the check engine light is on.
Old Sep 20, 2010 | 06:48 PM
Fordfanatic4life's Avatar
Fordfanatic4life
a blown plug will make your engine sound like a giant air pump...
Old Sep 20, 2010 | 09:01 PM
bill11012's Avatar
bill11012
Modular motor junkie
You will need to read the codes to really do much with it, autozone will do that free.
Is it like a skip or a surge when you sit in drive with you foot on the brake?
If it feels like the engine is reving up/surging or the tach shows it is than you need to check the vacuum lines. The intake has a big elbow that is prone to rotting out.
If its just more of a skip ( which is more likly) than odds are its a bad coil ( the COP for that cylinder) and the trouble code will tell you which one.
Welcome to FTE!
Old Sep 20, 2010 | 09:19 PM
willtim1234
It is reving/surging with my foot on the brake.Seems to be running OK while moving.
Old Sep 20, 2010 | 09:29 PM
bill11012's Avatar
bill11012
Ok, First thing to check is the vacuum lines around the throttle body for any rotting, leaks or loose parts.
Check the air filter housing too. Make sure the two halves are put togather right and the clamp is on.
If thats all looks good then get us the codes that are setting the CEL ( check engine light ) and we can go from there.
Old Sep 20, 2010 | 11:36 PM
Fordfanatic4life
if its not the vacumm line you prolly have a IAC valve issue...
Old Sep 21, 2010 | 03:20 PM
willtim1234
Cracked vacuum line.Dealer charged $195.00.Did I get screwed?
Old Sep 21, 2010 | 04:49 PM
mwsF250's Avatar
mwsF250
Did they fix the problem?
How long did it take to diagnose?
Repair?
What did parts cost?
Old Sep 22, 2010 | 09:23 AM
Moto Mel's Avatar
Moto Mel
No, not if it was something that was not obvious. We all have to understand that there are huge exspenses involved in operating a business as large as a dealership. If they don't charge for every basic diagnosis and part they will not be in business for very long.
Glad you got it fixed.
Old Sep 22, 2010 | 12:43 PM
willtim1234
Thanks for all the help.This site has saved my a lot of money and time.
