Sponsored by: Auxito
2" - 3" Lift Kit
Old Sep 19, 2010 | 05:56 PM
soupclub's Avatar
soupclub
2" - 3" Lift Kit
Need some advice on a lift kit for my 2k F150, supercab, 4x4. Want to lift it 2 -3 inches and would like to take the path of least resistance.
BUT, will go the other way if it is better. You guy's are the subject matter experts so coming here first.
Thx,
Dana
Old Sep 20, 2010 | 08:00 PM
soupclub's Avatar
soupclub
looking to see if a body lift or suspension lift is preferable.
Thx,
Dana
Old Oct 2, 2010 | 07:26 PM
petroskie's Avatar
petroskie
everybody is against these but they work well, go here
2" Lift Kit
this kit is very nice and easily done on a saturday, would still be ok with factory size shocks, but dont forget an alignment. could easily clear 33s or stuff 35s
Old Oct 2, 2010 | 11:46 PM
Alex7191's Avatar
Alex7191
just crank the t-bars with the stock keys up a couple inches and put some taller blocks in the rear. or a 3 inch body lift. these trucks pull off a BL very well.
Old Oct 2, 2010 | 11:56 PM
petroskie's Avatar
petroskie
problem with cranking the t-bars is you cant always do a correct alignment, and your t-bars have a higher stress and can at times lead to busted t-bars. with the keys theres the same stress as factory its just the keys are cut a diff angle to allow for the lift and still get almost the same comfort and alignment. but sure lots of ppl crank t-bars and they last i cant argue that, but i have seen them break too, plus the much stiffer ride
Old Oct 2, 2010 | 11:57 PM
petroskie's Avatar
petroskie
body lifts are nice, but more labor than the t-bar keys and blocks, costs are close to the same for a good kit that has everything
Old Oct 3, 2010 | 12:20 AM
Alex7191's Avatar
Alex7191
you can crank the stock keys up a couple inches safely and be able to get it aligned. no matter what you use to crank them you're still increasing the preload on the bars which will make it stiffer
