Headlight Problems
Old Sep 19, 2010 | 04:49 PM
CAL 250's Avatar
CAL 250
Headlight Problems
Here is a nothre puzzle on me 66 F250. When I turn the headlights on, they stay lit for about 5 seconds, then start blinking, and then go out. If I shut them off, the same pattern occurs again.
I put a new switch in a couple of years ago and didn't have a problem until now.
Anyone have any ideas?
Old Sep 19, 2010 | 04:57 PM
Scifi266's Avatar
Scifi266
check all your grounds, it could be that. also, have you checked the wires leading to the headlights?
Old Sep 19, 2010 | 05:13 PM
CAL 250's Avatar
CAL 250
Checked the wires to the lights. There is no difference if I move any of the wires, the lights flash even when it is sitting still. I will check the grounds and see what happens.
Thanks
Old Sep 19, 2010 | 06:00 PM
CAL 250's Avatar
CAL 250
Updates: Check the all the grounds I could find (some loose) but no improvement. When I turn on the dome light, and parking lights there is no problem. It is only when I turn the headlights on that they start flashing.
Has anybody gone through a similar issue? I know electrical issues can be tricky.
Old Sep 20, 2010 | 12:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The dimmer switch is foot activated, located on the toe board below the hand brake lever.
What usually happens to it is: When you click the button for high beams, the headlights will either flicker on/off, or go off.
Try cleaning the contacts, or replace the switch. Ford used the same dimmer switch on darn near everything for over 30 years.
Old Sep 20, 2010 | 11:02 AM
CAL 250's Avatar
CAL 250
Thanks
I figured the same thing and went down to the parts place and got a new dimmer switch. But after the intallation, the lights would do the same thing on the high beams. After running out of ideas, I tried playing with the light switch a little more. I found out that I could slide it into a position just before it maxed out and the high beams stay on without flickering!? I am thinking the switch may be the problem even though I replaced it 2 years ago. Some of these aftermarket parts just don't last very long!
Old Sep 21, 2010 | 01:02 PM
airharley's Avatar
airharley
There is a metal clip/spring tang inside the light switch that can affect what you are describing. Don't confuse it with the one you can see outside the housing that is a rheostat for the interior light brightness. If you replace the light switch it will go away. Or you can drill out the 4 solid rivets (only remove the bucking) and pull the switch apart and clean the contacts. I simply replaced the rivets for screws on mine so I can clean it out when I need to. You can still get the switch from most part places. Some better then others in quality though.
Old Sep 21, 2010 | 07:03 PM
CAL 250's Avatar
CAL 250
Didn't think you could acutally take them apart like that. I did check and the switches are available at most auto parts stores. Seems like a similar design has been used on a number of vehicles for a long time. Prices are a little strange...I found a web based site that sells them for under 3 bucks? It seems like most range from about $16 to $24 around here.
I will probably by a new one for a quick fix, and then open the old one as you describe.
Thanks
