DTC CODES
Old Sep 19, 2010 | 01:20 PM
TheSpecialist5's Avatar
TheSpecialist5
DTC CODES
Hi, these are the codes I pulled from an 05 F-350 6.0 - Any thoughts?
#1 P2285 - Injector control pressure sensor circuit Low
#2 P0403 - Exhaust gas recirculation control circuit
#3 P0405 - Exhaust gas recirculation sensor A circuit low
#4 P0113 - Intake Air Temperature sensor 1 cicuit High Input
#5 P0403 - same as above
#6 P0405 - same as above
#7 P2285 - Injector control pressure sensor circuit low
Any Ideas? Short or wire chafing somewhere?
Won't start
<!-- / message -->
Old Sep 19, 2010 | 01:30 PM
brickie's Avatar
brickie
Unplug the ICP and see if it will start.2285 could be a bad sensor.
Old Sep 19, 2010 | 04:02 PM
bismic's Avatar
bismic
I agree w/ brickie.
Sounds like IAT1 might be bad also (or shorted to power).
Do you have an aftermarket intake or is it stock?
Old Sep 19, 2010 | 04:06 PM
bismic's Avatar
bismic
Looks like you have two threads going on the same issue.
SteveBricks advised you to unplug the ICP and it did not help w/ the no-start.
Look into the IAT1.
Also, in the Tech Folder is a "no-start" troubleshooting thread that can tell you how to measure the high pressure oil pressure from the ICP voltage.
Old Sep 19, 2010 | 06:10 PM
TheSpecialist5
codes
Yes, I wanted the code issue in the title. The truck is all stock
Old Sep 19, 2010 | 06:11 PM
TheSpecialist5
What is the IAT1?
Old Sep 19, 2010 | 06:17 PM
cheezit's Avatar
cheezit
iat1 is the air intake sensor in the air cleaner. odds are its unpluged. odds arre you have an issue with the icp seonsor and or connector.
all the egr codes can be caused by the p2285 as well, however with the p0405 you may still have a egr valve issue too.
Old Sep 19, 2010 | 06:22 PM
brickie's Avatar
brickie
Why did you start two threads for the same problem?It would be easier on those with the time to help you if you posted once.IAT1 is intake air temperature do you have an aftermarket oiled intake filter?At the top of the forum there is a tech folder read it and you will learn a ton,this is the sensor you are getting a code for Page 59: Electrical Components
Old Sep 19, 2010 | 06:25 PM
brickie's Avatar
brickie
Gezz I type slow,thanks for jumping in cheezit.
Old Sep 19, 2010 | 06:42 PM
TheSpecialist5
I am so sorry, I was trying to get the code thing in the title, and I was having a little trouble navigating the site. I do very much appreciate the time people take to help out.
I will look into becoming a supporter, the site seems friendly and more than helpful.
Thanaks everyone!
Old Sep 19, 2010 | 06:43 PM
cheezit's Avatar
cheezit
no problem at all. thank you. its a great site full of more info then any others I have found.
Old Sep 19, 2010 | 07:48 PM
TheSpecialist5
Incidently bismic, I would love those spreadsheets I read about on the site somewhere. You can email them to me, I would appreciate it.
Old Sep 19, 2010 | 07:55 PM
bismic's Avatar
bismic
Be glad to. I can not email them through the FTE server, so I need an email address (PM me, Visitors message me, or post it).
BTW - using the excel "find" feature makes them pretty handy (IMHO anyway)
Old Sep 20, 2010 | 08:44 PM
TheSpecialist5
How do all, I have a question, non-related to the code post.
What are the two fuses or relays in a little black box, clipped to the drivers side battery box, on the fender side?
Old Sep 20, 2010 | 08:59 PM
cheezit's Avatar
cheezit
off the top of my head Im wanna say they are for 4x4 if i remember.
