valve to piston clearance
Old Feb 20, 2003 | 12:40 PM
justo2000_2000's Avatar
justo2000_2000
Does anyone know of any reputable machine shops in eastern KY to groove some pistons in a 351w? Reason being, I have plans to install a Lunati special purpose mechanical/solid cam w/290/300 adv. duration and .540/554 lift. . Thanx in advance.
Old Feb 25, 2003 | 09:15 AM
quadzjr's Avatar
quadzjr
just another Rockwell looser
Fly cutting pistons is a very simple task that almost any machine shop can do. (Compared to the other work that is performed like milling heads, aand porting.) There are kits that you can do it yourself, but very time consuming. as for an actual machine shop i can't help you. but fly cutting or notching pistons is simple and as long as you match all of the pistons weight and balance them It will be ok.
SideWinder4.9l
Kentucky Chapter
17
Sep 16, 2025 05:40 PM
mustangmike6996
All Other Items for Sale
Aug 10, 2014 09:28 AM
renchtrnr
New Member Introductions
Jun 23, 2014 11:08 AM
jhooch
May 22, 2014 01:35 PM
