Really High-End Brakes
Old Sep 18, 2010 | 08:53 PM
bobwires's Avatar
bobwires
Has anybody seen some really nice brakes on a dent? I'm talking drilled and slotted 2-piece huge diameter rotors, 6 piston calipers.
I've seen lots of guys complain about stopping power, and complain about the price of really nice brakes, but I've never seen the better Wilwood, Baer, etc on one of these trucks. The Pro-Touring crowd doesn't even think twice about $6000 for all new brakes front and rear, but most of us are way too cheap for that. Has anybody done it? Because long-term, I'm sure thinking about it!
Probably have to have some custom brackets, but other than that the obstacle is always price.
anybody got pics?
Old Sep 19, 2010 | 02:19 AM
jlaudio_f100's Avatar
jlaudio_f100
I stay away from drilled rotors. If you heat them up then go splashing through cold water they crack there first. If you get a good (not eBay) set of "JUST" slotted rotors, new pads, and new calipers then I think it will be just fine. These trucks weren't meant to stop on a dime.
Old Sep 19, 2010 | 04:08 AM
RVDan's Avatar
RVDan
The stock dual piston calipers are pretty good items to start with. Just upgrade your brake lines to braided items for more braking pressure, consider a better master cylinder, and of course do the rear disk swap.
I have the braided front lines, dual chamber brake booster, and the rear disk parts are sitting on the shelf waiting for me to get around to it.
Old Sep 19, 2010 | 04:41 AM
Kalve's Avatar
Kalve
I am needing to replace the brakes on mine this winter. What is a good brand to go with an ones to stay away from? An were did you get a dual chamber brake booster at & what do you change out to go disc brakes on these trucks?
Old Sep 19, 2010 | 02:23 PM
bamaf150's Avatar
bamaf150
No they werent and thats a good reason to do the upgrades.
Old Sep 19, 2010 | 05:13 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It's not that hard for a 2wd truck to lock up all 4 tires with stock brakes.
How would $6000 brakes make that any different?
Josh
Old Sep 19, 2010 | 05:47 PM
bobwires's Avatar
bobwires
any recommendations on a master cylinder?
I've heard that about drilled rotors, but I've never seen it. I think if I'm ever going sloshing through water they won't be hot to begin with. I could go either way.
Josh
2 reasons -
I'd like to have a versatile street truck/4x4. I'm planning a cummins swap to improve gas mileage and torque so it's a more practical work truck. I plan to have sway bars like the newer truck have with detachable mounts so if I want to go off road and need articulation it won't be a problem. On the street I want it to handle better, stop better, and get some attention as my shop truck. I have felt the difference quality brakes make in a car, and it is a huge difference. Also a lot of it is heat. I don't trust those stock components in my town full of hills. the stock brakes are all fresh, and they get pretty warm sometimes, and i don't really hot rod this truck.
cosmetics. when I stick nice rims on it I don't want stock brakes. I don't want painted old brakes either. I want big diameter brakes that make it look more like a pro-touring truck.
Old Sep 19, 2010 | 05:55 PM
perryg114's Avatar
perryg114
Convert to a hydroboost system that works off the power steering pump and is not limited to engine vacuum for boost.
Perry
Old Sep 19, 2010 | 06:15 PM
1979F350/460's Avatar
1979F350/460
I'm installing Wilwood 4 piston calipers on the rear and Ihave another set that I was going to try to make work in the front. I may also try a set of sStop Tech 6 piston calipers just not sure on the front rotor size and how it will all come togetther.
Old Sep 19, 2010 | 07:14 PM
bobwires's Avatar
bobwires
Perry
how big is the improvement over a vacuum design? especially since I'm not using brakes at higher RPMs or anything the vacuum boosters have always seemed sufficient. Is there more to it?
got pictures? sounds like a winner
Old Sep 20, 2010 | 02:51 AM
jlaudio_f100
Yeah ive done it. I have a 4wd so I heat up my rotors then drive through a creek then mud then heat up the rotors again so that's why I said that. You can also do this in the rain.
Old Sep 20, 2010 | 05:19 AM
Kalve's Avatar
Kalve
Were can you buy a dual chamber brake booster? An what vehicle does it come off of?
Old Sep 20, 2010 | 06:59 AM
1979F350/460
I'm still in the process of installing the rear stuff haven't looked at the front yet to see how I can make it work. I'll take some pics sometime this week and post them up.
Old Sep 20, 2010 | 07:22 AM
perryg114's Avatar
perryg114
Here is an article from the oilburners.net you may have to register to view it. It goes through the process of converting one. I don't know about on your truck but the big 3/4 and 1 ton trucks have never had very good brakes at least the ones prior to the powerstroke era always had crappy soft brakes that you have to push to the floor to get any brakes at all especially pulling a load. The reason is the booster was not big enough so they would put in a small master cylinder that the booster could handle but it took alot of pedal to get them to stop.
Oilburners.net
Perry
Old Sep 20, 2010 | 11:00 AM
alie-r's Avatar
alie-r
that booster is for a F350 with the dual piston calipers.
i have done this swap a few months ago on my F250 and its a hell of a difference.
andre
