Running Slugish
Old Sep 18, 2010 | 05:08 PM
MY4X4F350's Avatar
MY4X4F350
Running Slugish
I have an 05 F350 6.0l and it is running slugish when its cold but runs fine once the engine gets up to operating tempature. Any ideals what it could be.
Old Sep 20, 2010 | 07:41 AM
l-m tech's Avatar
l-m tech
injector stiction.this is when the injectors have a varnish build up on the fuel or oil side,more likeley on the oil side of the injector,that causes them not not function as they should until the temp in the oil gets up to almost160 degrees and they function fine.try plugging it in and see if it helps.
Old Sep 20, 2010 | 06:37 PM
MY4X4F350's Avatar
MY4X4F350
Thank you for your response.I have 1 more question, How do I get it cleaned up?
Old Sep 20, 2010 | 06:48 PM
cheezit's Avatar
cheezit
you can have the ecm reflashed and see if that helps.
by replacing the injectors if its bad enugh.
you can try to change the oil with 5-40 and see if that helps.
Old Sep 20, 2010 | 07:03 PM
brenthalamue's Avatar
brenthalamue
What are you referring to when you say "reflashed"? I have seen that term used several times. Sorry, if its an ignorant question.
Old Sep 20, 2010 | 07:05 PM
cheezit's Avatar
cheezit
its ok I awnser ignorant question's too.
that is reprograming the pcm,tcm,ficm.
Old Sep 20, 2010 | 07:08 PM
brenthalamue
Thank you, Master.
460 FORD MAN
Jan 26, 2013 12:03 PM
jmh725
Jan 10, 2010 09:03 PM
bigbuck136
Sep 30, 2008 05:17 PM
53f100
Feb 14, 2005 10:31 AM
marriedguy1
Aug 9, 2002 09:25 PM
