rust remove
Old Sep 18, 2010 | 04:17 PM
lbrauer's Avatar
lbrauer
rust remove
<TABLE border=1 width="100%"><TBODY><TR><TD vAlign=top width="24%" align=left></TD><TD height=73 vAlign=center width="76%" colSpan=3 align=left>
Electrolytic derusting
</TD></TR><TR><TD bgColor=#000099 colSpan=4>
By Ted Kinsey
</TD></TR><TR><TD bgColor=#00ffff colSpan=4>
Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Features | Search | Hoo-ya Shop
</TD></TR></TBODY></TABLE><TABLE width="83%" align=center height=133><TBODY><TR><TD height=127 width="59%"> This article was reproduced with permission of Ted Kinsey, the original author. We had a lot of feedback on this Tech Tip and Randy Baumann compiled the additional information and prepared an update (June 2005). It is available in a pdf format. Please support all copyright issues, we all work hard on that which we produce.</TD><TD width="21%">
</TD><TD width="20%">******** type=text/javascript><!--google_ad_client = "pub-3699152422294193";google_ad_width = 160;google_ad_height = 90;google_ad_format = "160x90_0ads_al_s";google_ad_channel = "";google_color_border = "FFFFFF";google_color_bg = "FFFFFF";google_color_link = "0000FF";google_color_text = "000000";google_color_url = "008000";//-->*********>******** type=text/javascript src="http://pagead2.googlesyndication.com/pagead/show_ads.js"> *********>******** src="http://googleads.g.doubleclick.net/pagead/test_domain.js">*********>******** src="http://pagead2.googlesyndication.com/pagead/render_ads.js">*********>********>google_protectAn dRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);*********>******** height=90 marginHeight=0 src="http://googleads.g.doubleclick.net/pagead/ads?client=ca-pub-3699152422294193&format=160x90_0ads_al_s&output=ht ml&h=90&w=160&lmt=1284843935&ea=0&color_bg=FFFFFF& color_border=FFFFFF&color_link=0000FF&color_text=0 00000&color_url=008000&flash=10.0.32.18&url=http%3 A%2F%2Fwww.stovebolt.com%2Ftechtips%2Frust%2Felect rolytic_derusting.htm&dt=1284843935968&shv=r201009 09&jsv=r20100903&correlator=1284843935968&frm=0&ad k=178469593&ga_vid=1706298501.1284843936&ga_sid=12 84843936&ga_hid=1093052714&ga_fc=0&u_tz=-300&u_his=0&u_java=1&u_h=819&u_w=1024&u_ah=792&u_a w=1024&u_cd=32&u_nplug=0&u_nmime=0&biw=617&bih=261 &ref=http%3A%2F%2Fwww40.addr.com%2F~merc583%2Fmopa r%2Fp15pages%2Flinks.html&fu=0&ifi=1&dtd=219" frameBorder=0 width=160 allowTransparency name=google_ads_frame marginWidth=0 scrolling=no>*********></TD></TR></TBODY></TABLE>
<HR width=500>What is the method?
Electrolysis is a technique for returning surface rust to iron. It uses the effect of a small low voltage electric current and a suitable electrolyte (solution). It has advantages over the old standbys like vinegar, Coke, muriatic acid, naval jelly, wire brushing, sand blasting, etc. Those methods all remove material to remove the rust, including un-rusted surfaces. With many, the metal is left with a "pickled" look or a characteristic color and texture. The electrolytic method removes nothing: by returning surface rust to metallic iron, rust scale is loosened and can be easily removed. Un-rusted metal is not affected in any way.
What about screws, pivots, etc that are "rusted tight"?
The method will frequently solve these problems, without the need for force, which can break things. Is it safe? The solutions used are not hazardous; the voltages and currents are low, so there is no electrical hazard. No noxious fumes are produced. The method is self limiting: it is impossible to over clean an object. Small amounts of hydrogen are emitted in the electrolysis process. Good ventilation or an outdoor work site is all that is needed.
Where did this method come from?
Electrolysis is a standard technique in the artifact restoration business. I wrote this up for the Chronicle of the Early American Industries Association a few years back. Most of the tool collectors around here use it.
What do I need?
A plastic tub; a stainless steel or iron electrode, water and washing soda (Arm & Hammer, for example) and a battery charger. About a tablespoon of soda to a gallon of water. If you have trouble locating the washing soda, others have reported success with baking soda. Also household lye will work just fine. It's a tad more nasty -- always wear eye protection and be sure to add the lye to the water (NOT water to lye!!!) The solution is weak, and is not harmful, though you might want to wear gloves. NOTE: It is the current that cleans, not the solution; nothing is gained by making a more concentrated solution -- DON'T!
How long does the solution last?
Forever, though the loosened rust will make it pretty disgusting after a while. Evaporation and electrolysis will deplete the water from the solution. Add water ONLY to bring the level back.
What about the stainless/iron electrode?
The electrode wants to be large (within reason); if possible, larger than the object being cleaned. The iron electrode works best if it "surrounds" the object to be cleaned, since the cleaning is "line of sight" to a certain extent. An iron electrode will be eaten away with time. Stainless steel has the advantage (some alloys, but not all) in that it is not eaten away. I have had good success with sheet stainless salvaged from a paper towel dispenser. It has a large surface area and is easily shaped to fit the container.
How do I connect the battery charger?
THE POLARITY IS CRUCIAL!! The iron or stainless electrode is connected to the positive (red) terminal. The object being cleaned, to the negative(black). Submerge the object, making sure you have good contact, which can be difficult with heavily rusted objects. Get it backwards and your object will be relentlessly eaten away! Make connections on a part of your electrode that protrudes out of the solution, or your clamps will erode rapidly.
How do I know if it is working?
Turn on the power. If your charger has a meter, be sure some current is flowing. Again, on heavily rusted objects, good electrical contact may be hard to make-it is essential. Multi-part objects may not have good electrical connections between them. Fine bubbles will rise from the object when cleaning is in progress.
How long do I leave it?
The time depends on the size of the object and of the iron electrode, and on the amount of rust. You will have to test the object by trying to wipe off the rust. If it is not completely clean, try again. Typical cleaning time for moderately rusted objects is a few hours. Heavily rusted objects can be left over night.
How do I get the rust off after I remove the object?
Rub the object under running water. A paper towel will help. For heavily rusted objects, a plastic pot scrubber can be used, carefully. Depending on the amount of original rust, you may have to re-treat. The amount of mechanical action will depend on the fragility of the object. Use your discretion.
My object is too big to fit. Can I clean part of it?
Yes. You can clean one end and then the other. Lap marks should be minimal if the cleaning was thorough.
After I take it out, then what?
The clean object will acquire surface rust very quickly, so wipe it dry and dry further in a warm oven or with a hair dryer/heat gun. You may want to apply a light oil or a coat of wax to prevent further rusting.
Will the method remove pitting?
No. It only operates on the rust in immediate contact with unrusted metal. What's gone is gone. What will it look like when I am done? The surface of rusted metal is left black. Rusted pits are still pits. Shiny unrusted metal is untouched.
What about nickle plating, paint, japanning and the like?
Sound plating will not be affected. Plating under which rust has penetrated will usually be lifted. The solution is likely to soften most paints.Test with a drop of solution in an inconspicuous place. Remove wood handles if possible before treating.
How can I handle objects that are awkward to clean?
There are lots of variants: suspending an electrode inside to clean a cavity in an object; using a sponge soaked in the electrolyte with a backing electrode to clean spots on large objects or things that shouldn't be submerged (like with lots of wood)
How can I dispose of the solution?
The bath will last until it gets so disgusting that you decide it is time for a fresh one. There is nothing especially nasty about it-it's mildly basic-so disposal is not a concern, except you may not want all the crud in your drains.
Can I use metal containers?
This is highly risky. Galvanized metal can introduce zinc into the solution. If you have used lye, it will attack aluminum. You may have problems with electrical shorts, etc. Stick to plastic.
How can I clean odd shaped objects?
Be ingenious. Plastic PVC pipe and eave troughs, wooden boxes with poly vapor barrier, kids wading pools, etc.
<HR width="65%"> We had a lot of feedback on this Tech Tip and Randy Baumann compiled the additional information and prepared an update (June 2005). It is available in a pdf format. Please support all copyright issues, we all work hard on that which we produce. Be sure to check out our extensive Forums discussions -- from General Truck talk, Electrical Bay, Big Bolts, Panels and Burbs, Engine and Driveline, Paint and Body, Interiors, Tool Chest -- The Stovebolt Collective can help in your quest and walk you through the mire and magic of working with old iron. ~~ Editor .
<HR><CENTER><TR><TD colspan="4" bgcolor="#00ffff">
</TD></TR></CENTER><HR align=left>
<TABLE border=0 width="100%"><TBODY><TR><TD height=32 width="21%">******** type=text/javascript><!--google_ad_client = "pub-3699152422294193";google_alternate_ad_url = "http://www.stovebolt.com/mall/";google_ad_width = 200;google_ad_height = 90;google_ad_format = "200x90_0ads_al_s";google_ad_channel ="";google_color_border = ["FF0000","336699","000000","B4D0DC"];google_color_bg = ["FFFFFF","FFFFFF","F0F0F0","ECF8FF"];google_color_link = ["0000FF","0000FF","0000FF","0000CC"];google_color_url = "008000";google_color_text = ["000000","000000","000000","6F6F6F"];//-->*********>******** type=text/javascript src="http://pagead2.googlesyndication.com/pagead/show_ads.js">*********>******** src="http://pagead2.googlesyndication.com/pagead/render_ads.js">*********>********>google_protectAn dRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);*********>******** height=90 marginHeight=0 src="http://googleads.g.doubleclick.net/pagead/ads?client=ca-pub-3699152422294193&format=200x90_0ads_al_s&output=ht ml&h=90&w=200&lmt=1284843936&ea=0&alternate_ad_url =http%3A%2F%2Fwww.stovebolt.com%2Fmall%2F&color_bg =ECF8FF&color_border=B4D0DC&color_link=0000CC&colo r_text=6F6F6F&color_url=008000&flash=10.0.32.18&ur l=http%3A%2F%2Fwww.stovebolt.com%2Ftechtips%2Frust %2Felectrolytic_derusting.htm&dt=1284843936203&shv =r20100909&jsv=r20100903&prev_fmts=160x90_0ads_al_ s&correlator=1284843935968&frm=0&adk=3975560557&ga _vid=1706298501.1284843936&ga_sid=1284843936&ga_hi d=1093052714&ga_fc=0&u_tz=-300&u_his=0&u_java=1&u_h=819&u_w=1024&u_ah=792&u_a w=1024&u_cd=32&u_nplug=0&u_nmime=0&biw=617&bih=261 &ref=http%3A%2F%2Fwww40.addr.com%2F~merc583%2Fmopa r%2Fp15pages%2Flinks.html&fu=2&ifi=2&dtd=93" frameBorder=0 width=200 allowTransparency name=google_ads_frame marginWidth=0 scrolling=no>*********></TD><TD height=32 width="1%"> </TD><TD height=32 width="78%">
Copyright © 1995-2010 | Stovebolt.com | Mechanicsville, Maryland
No parts of this site, its contents, photos or graphics may be used without permission.
******** type=text/javascript> var gaJsHost = (("https:" == document.location.protocol) ?"https://ssl." : "http://www."); document.write(unescape("%3Cscript src='" + gaJsHost +"google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E")); *********>******** type=text/javascript src="http://www.google-analytics.com/ga.js">*********>******** type=text/javascript> var pageTracker = _gat._getTracker("UA-3825946-1");pageTracker._initData(); pageTracker._trackPageview(); *********>
Old Sep 18, 2010 | 04:36 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Larry,not to bash Scrubs - I like all old iron - but it would have been better just to post the link,me thinks.
Old Sep 18, 2010 | 05:10 PM
lbrauer's Avatar
lbrauer
I never thought of just doing that. That would have been better. Thanks next time I will just post a link.
Old Sep 18, 2010 | 05:29 PM
fifty-two_f1's Avatar
fifty-two_f1
Is this a good way of getting light surface rust off of chrome? or will it eat the chrome off?
Old Sep 18, 2010 | 08:59 PM
BlueOvalRage's Avatar
BlueOvalRage
Hey, Jordan, you don't want to use electrolysis on chromed parts. The process is very similar to the plating process - except that it works backwards. It will "unplate" stuff. During the winter when I'm working on smaller resto projects, I've usually got my electrolysis rig running 24/7. No blasting mess and it's virtually effortless!
Old Sep 19, 2010 | 09:13 AM
1952's Avatar
1952
Try Barkeeper's friend, it is used by barkeepers for their nonferrrous metals. You could also try wood bleach from a hardware store. My research on wood bleach for other purposes led me to a BMX forum where I discovered bike people use it on old bikes. I would try it on scrap first, though.
Old Sep 19, 2010 | 09:18 AM
1952's Avatar
1952
I use this method a lot as well on many things, including carburetor linkage pieces and the cast iron bases. PH Plus from Walmart is pretty cheap and is sodium carbonate. I have use powdered lye and it really makes any paint go away, you just have to use gloves, or your skin will slip away after awhile.
Old Sep 19, 2010 | 10:54 AM
Daytona F1's Avatar
Daytona F1
"Electrolysis is a technique for returning surface rust to iron"
You have got to be kidding me!
Electrolysis is a technique for separating by using direct electric current to drive an other-wise non-spontaneous reaction. In English, it makes thing separate.
For example, if you have a boat and you allow an electric current to pass through the water around your dock or boat, all metals, excluding higher grades of stainless, will oxidize (corrode, rust, etc.). You have separated the oxygen molecules from the metal.
Electroplating is a different process but it doesn't change rust in iron either.
Old Sep 19, 2010 | 11:02 AM
ibuzzard's Avatar
ibuzzard
I thought electrolysis was for hair removal.Wait,I don't need that........
Randy5556
Sep 3, 2008 07:30 PM
bigearl1369
N. California Chapter
Jul 3, 2008 05:11 AM
M55bird
Dec 15, 2007 11:06 PM
polarisman
Nov 1, 2007 08:19 AM
