6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Time To build a 08 - 10 Excursion (pics)
Old Sep 18, 2010 | 11:37 AM
pdombrowicki's Avatar
pdombrowicki
Finally picked up an Ex. Its a 2002 V10 with leather 4x4 130,000 miles. I paid $1480 for it and another $700 to $800 to get it home from PA to WI. Now to find a wrecked 08-10 with a 6.4l
Old Sep 18, 2010 | 12:12 PM
cartmanea's Avatar
cartmanea
That'll be sweet! You should do the '08-'10 front clip as well for the larger fender openings and newer look.
Old Sep 18, 2010 | 12:51 PM
pdombrowicki
Its going to be 08 -10 fronted, motor,drive line, suspension, wheels, dash and interior.
Old Sep 18, 2010 | 01:07 PM
cartmanea's Avatar
cartmanea
Are you going to try to find a rollover and use the whole frame? I'm sure the length could be adjusted and mounts modded to work, might be easier than swapping everything to the '02 frame.
Old Sep 18, 2010 | 01:24 PM
senix's Avatar
senix
interesting..look forward to the results.
Old Sep 18, 2010 | 03:07 PM
pdombrowicki
Plan on buy a roll over. Also plan on cutting the factory welds by the front cross member and swapping it out for the 08 - 10 front frame section. Everything appears to be the same with the frame except for the coil overs.
Old Sep 18, 2010 | 04:32 PM
cartmanea's Avatar
cartmanea
The frames were changed in '05, but I don't know what all was changed. I thought they changed width slightly, but it could just be frame strength that changed. Using '08 suspension will mean moving the rear spring hangers as well.
Old Sep 18, 2010 | 09:05 PM
pdombrowicki
I can't imagine that they changed the frame width because the cabs are the same from 99 to 11. If anything the strength has changed and the front suspension. As far as the rear end I will probably just changed the rear end so I have the correct back spacing for the new style wheels. I have a cd with all the frame dimensions, wiring diagrams and all that fun stuff right from ford. Just got to go and print it off and start comparing. Don't think it will be to difficult to figure out.
Old Sep 18, 2010 | 09:07 PM
cartmanea's Avatar
cartmanea
Definitely move the hangers and use the '08+ rear springs, they ride a lot better. If you want a kit with instructions, PMF makes an '08 rear spring conversion kit.
Old Sep 18, 2010 | 11:02 PM
kper05's Avatar
kper05
Was nice to see that F350 come back to life.
It will be great to watch this project progress, granted this is much more involved.
Old Sep 19, 2010 | 01:08 AM
kane gray's Avatar
kane gray
How horrible is the frame??
Old Sep 19, 2010 | 08:50 AM
pdombrowicki
Don't now yet. Truck will be here on Tuesday. Then I will start the disassemble and take a lot of pics.
Old Sep 19, 2010 | 12:07 PM
cartmanea's Avatar
cartmanea
The front subframe looks pretty bad, but not terrible. Since the impact was centered the rest of the frame shouldn't be too bad, little diamond, etc.
Old Sep 19, 2010 | 12:08 PM
senix's Avatar
senix
Are you kidding...that will just buff out.
Old Sep 19, 2010 | 12:28 PM
pdombrowicki
By the way it looks I don't think the frame diamond behind the fire wall. Just the front frame rails are pushed around. It looks bad because the front tire is of the rim.
