Will Not Turn - Steering Is Locked! Help
It is not like the power steering is out and it is hard to turn - it will not turn at all. I peeked under and was getting dark, but there are no apparent broken parts. The left wheel that is off the ground does have small amount side-to-side play but no up-and down. No way to drive this safely and will need tow if we cannot figure out. I do not think the truck has 50k miles on it. Drives it little as the v-10 is a ***** on gas.
Can anyone help with where to start?? Please don't flame me but I drive and wrench little Hondas and Saturns so no 4x4 experience.
If it's locked up it sounds to me like the anti-theft lock on the steering wheel may have malfunctioned. I'd suggest playing with the lock cylinder and seeing if anyting changes.
Side to side movement on a front wheel is not a good thing. This may or may not have anything to do with his steering problem, but either way it has to get fixed. Earlier this year in a previous job I let a steering problem go to far on my work truck. I got it fixed but it got bad enough it nearly caused an accident. The lesson I learned was to NOT screw around with steering components and to get issues fixed quickly!
If the steering wheel lock isn't causing his troubles you'll have to take a good look at the entire steering linkage. Something's probably awry with either the steering gear or linkage, and it may not be easy to figure out. If the truck was "wobbly" he may have a suspension problem as well. How does the truck sit when it's on level pavement?
Thanks for the response. To clarify some information, it does not seem to be any kind of ignition lock issue unless i am misunderstanding. From this morning...
You can start the truck up on the stands. The wheel is free but you can only get it to turn to about 10:30 - 1:30 left to right. You can hear the pump when it binds. After it gets to that point it is not like it is hard to turn. You cannot turn it past that point at all.
Only thing I have ever encountered on this was with my 72 T-Bird and happened while going down interstate and the steering started pulling left and could not get it back. Steering gear box fried. I skidded across 2 lanes and came to rest against the median.
I have seen lots of search posts on play but none on this except for some bushing/bearing behind the steering wheel in the column. Anyone else?
I would suggest disconnecting the steering box from the linkage to see whether or not it's the box or the linkage. Don't know the details on how you'd do this, I'd suspect you probably disconnect the end of the pitman arm from where it connects to the rest of the linkage.
With the truck up on jacks you should be able to grab a wheel and turn right to left. It should just flop around.
What ever you do dont spin the wheel around! You want every thing to line back up when your done.
Sorry about that. There is no outcome yet. He was busy over the weekend in the yard and I was putting a starter on the minivan, replacing a radiator on the honda, and piston soaking the saturn. He may just give a case of beer or a few packs of smokes to the mechanic he uses to look at it in the driveway to see whats wrong and if we can DIY. I will post result when done. Thanks for the help so far.
Good luck!
