Oil cooler kits
Old Sep 16, 2010 | 04:05 PM
mabc926's Avatar
mabc926
Oil cooler kits
Anyone have a website or know of a parts store that I can get a kit from to rebuild my oil cooler?
Old Sep 16, 2010 | 04:59 PM
greywynd's Avatar
greywynd
Not saying you can't find them elsewhere, but I've never seen or heard of a 'kit' just individual gaskets.
Ford and IH part numbers are below though.
2 - Oil cooler O rings Ford 1C3Z-6K649-BA
2 - Oil cooler O rings Ford 1C3Z-6C610-BA
1 - Oil cooler gasket Ford E3TZ-6A636-G
1 - Oil cooler gasket Ford E3TZ-6A636-H
International part #s (bag of 2 rings)
-thicker ring 1804414C1
-thinner ring 1807563C1
gasket 1804378C2
gasket 1804377C4
Old Sep 16, 2010 | 05:09 PM
mabc926's Avatar
mabc926
I didn't know if there was a kit or not, I guess it was just wishful thinking
Anyways thanks for the info, and does anyone know if the gaskets are metal and can be reused with some copper coat?
Old Sep 16, 2010 | 06:43 PM
fonefiddy's Avatar
fonefiddy
You'll need new ones.
Old Sep 16, 2010 | 07:12 PM
greywynd's Avatar
greywynd
The gaskets are paper with a bead of sealer on them already, install them as is, on good clean (and dry if possible) surfaces.
They are cheap enough (think I paid 6-8 bucks Canadian?) that it's not worth re-using them for the chance of a leak.
Old Sep 16, 2010 | 07:39 PM
1994F2507.3L's Avatar
1994F2507.3L
Search for 'engine oil cooler' | O'Reilly Auto Parts
Old Sep 16, 2010 | 08:12 PM
mabc926's Avatar
mabc926
Originally Posted by 1994F2507.3L
That shows 3 gaskets, I thought there was only 2?
Old Sep 16, 2010 | 09:27 PM
oreocreaming's Avatar
oreocreaming
theres only 2 used, there are 2 different types because the oil cooler runs all the way though the 03 7.3l. the kit covers all of them. cheaper to waste a gasket then have packaging for a different cooler and needing stock space in the auto parts places
Old Sep 16, 2010 | 09:31 PM
mabc926's Avatar
mabc926
Ah ok, so then all I'd have to order would be the o rings from ford....doesn't sound to bad.
Thanks for all the info guys!
Old Sep 16, 2010 | 09:43 PM
oreocreaming
ya, gaskets from ford are 8 bucks, get em from auto parts for 4. your not savin too much, but every penny counts.
Old Sep 16, 2010 | 09:52 PM
mabc926's Avatar
mabc926
8 bucks? I'll just save the hour drive to O'rilly's and get them all at ford then.
cookie88
16
May 24, 2012 08:47 AM
BobbyB
Oct 13, 2011 10:54 PM
smokersteve
May 24, 2011 07:33 PM
wulfman
Nov 30, 2010 11:17 AM
soobad
Jun 4, 2006 06:58 PM
