Sponsored by: Real Truck
C.B. Radios...
Old Sep 16, 2010 | 03:58 PM
CobraGT40's Avatar
CobraGT40
C.B. Radios...
Hey all
I was thinking of throwing a CB in my 2000 Superduty and was just wondering what would work out best...possibly that will fit into that cubbyhole under the radio ? What radio/antenna combos are you guys with CB's running ? How about a couple pics of locations ?
Thanks !
Old Sep 16, 2010 | 06:51 PM
smithrngr's Avatar
smithrngr
i am running a corbra 29ltd with wx and night watch that is mounted where the trash hook is.and i am running duel wilson 4ft antenna's on the mirrors and the combo works great at least for me it does,i get great reception in and out.
Old Sep 16, 2010 | 07:10 PM
1975StroppeBaja's Avatar
1975StroppeBaja
For me, Cobra 18 WX ST II by the trash hook and a Firestik II on the cowl.
Old Sep 16, 2010 | 07:15 PM
exiled's Avatar
exiled
I'll have to take pic of mine. I have mine mounted on the floor on the hump. I rather mine to be on the roof but this truck has a moon roof so I had to relocate have a galaxy 44 and really like it. Other than my coil ant. I like fire stix. They are easier to tune. What ever you run you don't want anything you have to cut to tune
. 18 feet of coax is easier to tune also. I don't know why that I. Run it out don't ball the excess up.
Old Sep 16, 2010 | 07:18 PM
camodown's Avatar
camodown
I also mounted the speaker below as well. Running a 4' Firestik antenna.
smithrngr's Avatar
smithrngr
the way my mount holes lined up it worked to just use the trash hook holes and use longer screws so i had no extra holes to deal with.
Old Sep 16, 2010 | 07:53 PM
Grumpy Moose's Avatar
Grumpy Moose
Here's mine
I had the headliner off installing cab marker lights so I figured what the heck:
Old Sep 16, 2010 | 08:13 PM
Thunderduckie's Avatar
Thunderduckie
We have a local shop here that sells a drive shaft hump mount. It has a built in external speaker and mounts really easily and hides your wires. I'm running a Cobra 148F GTX that has been modulated, clipped and pilled. Dead key 1/4 and swing 50 with talk back and Cobra power/echo mic. Mine tuned with 21 feet of coax and I run dual terminator coil over antennae mounted to extensions under my shell. Yeah, it's a Redneck thing.....
Old Sep 16, 2010 | 08:21 PM
Grumpy Moose
And here is my antenna
Wilson 5000 with 62" whip:
Old Sep 16, 2010 | 08:40 PM
i eat hybrids's Avatar
i eat hybrids
grumpy moose, like those lights on the service body! Do yopu have any more pics? And thanks for the idea, when i get my CB ill prob do a install like that.
Old Sep 17, 2010 | 01:07 PM
Grumpy Moose
Thanks. Yes, I have a ton more pictures of my various mods this year. I'll try to post some soon.
Old Sep 17, 2010 | 01:49 PM
BillyBob69's Avatar
BillyBob69
I dont have it installed anymore as I never used it but here is how I had mine done.....
Installed
Antenna
Old Sep 17, 2010 | 01:52 PM
CobraGT40's Avatar
CobraGT40
Installed
Antenna
That's awesome ! Is that a dash mounting kit ? Where did you get it ? Gives it a factory look, and that's what I was aiming for...
Old Sep 17, 2010 | 01:59 PM
jstnromero's Avatar
jstnromero
what kind of antenna is that BillyBob69?
Old Sep 17, 2010 | 02:01 PM
BillyBob69's Avatar
BillyBob69
Yep. It is a double din kit I got off of ebay for about $15. The CB has the speaker and mic connector on the front so that all worked out. It is just a tiny bit wider then a stock stereo so I have to shave the kit a little to get it to work.
Then had to shave the top and bottom flanges inside the dash opening. But once done, worked out pretty good.
