Windshield Wipers wont work
Old Jul 28, 2006 | 02:19 AM
fordinmudd's Avatar
fordinmudd
Tonight I gave my windsheild a spray of whiper fluid since the windsheild was dirty.But after some fluid ran down on the windsheild so I went to click my whipers on and nothing they wont go on at all.I checked the fuse and its good.why is it if i hit the button i can spary my windsheild with whiper fluid but I cant make the whipers go on at all if it rains?do i need a new whiper moter?or is it some other thing?..thanks in advance.
95 f 250 351 w auto 4x4 hd...a little over 200,000 miles and still going.(no ac)
Old Jul 28, 2006 | 08:56 AM
fordinmudd's Avatar
fordinmudd
would it be the switch?or would it be the motor for it?..i have a manual but its somewhat confusing.
Old Jul 28, 2006 | 02:59 PM
fordinmudd's Avatar
fordinmudd
If it is the switch where is it in the truck?My chiltons book doesnt show where it would be or what it looks like but im guessing this is what it may be?thanks any ifo will help.
Old Jul 28, 2006 | 03:46 PM
Franklin2's Avatar
Franklin2
Here's the diagram
http://www.autozone.com/images/cds/g...3d800a3a60.gif
The switch is part of the multi-function switch on the steering column, which has the wiper, turnsignals, hazards, and high-low beam switch all made together.
It uses a resistance value sent to the wiper module to tell the module what function you want.
I would go out to the wiper motor, and make sure you have voltage on the darkgreen wires.
Old Jul 28, 2006 | 09:51 PM
fordinmudd's Avatar
fordinmudd
oh boy i dont have a voltage meter.but i was reading some old post so i bought the switch so i know what it is now.now i have to figure out how it goes on.if it still doesnt work after i get it on then it must be the wiper motor those are about 125 bucks but if i need one i guess ill have to buy it.is there anyplace i can find out how to put the switch on at all?thanks
Old Jul 28, 2006 | 10:46 PM
Franklin2's Avatar
Franklin2
Here's a little bit of a guide.
http://www.autozone.com/servlet/UiBr...3d800a9e58.jsp
Old Jul 29, 2006 | 01:01 AM
fordinmudd's Avatar
fordinmudd
oh wow it says I have to remove the steering wheel i never did that before this is turning into a project.lol..dont you need a puller to get it off?
Old Jul 29, 2006 | 09:24 AM
Franklin2's Avatar
Franklin2
Yes, you will probably need a puller. The parts stores sell them.
Old Jul 29, 2006 | 06:24 PM
Nathane's Avatar
Nathane
How about you spend your $10 on a voltmeter before u spend it on a puller... I'd get a junkyard wiper motor if you have power to the wires going to it. If not, it's the switch
~Nate
Old Jul 30, 2006 | 01:05 AM
fordinmudd's Avatar
fordinmudd
ok i didnt get a chance to work on it today.I will get a voltmeter if you can tell me how I test the motor?My trucks a 95 f 250 it has wires that plug into the motor.what type of voltmeter should i get and where can i get one walmart or an auto parts store?thanks
Old Jul 30, 2006 | 08:42 PM
Franklin2's Avatar
Franklin2
A cheap one will work for now. Just make sure it has a dc scale on it. If you do not want to get a meter, you can get what they call a testlight. It's just a light that will glow when you touch it to a powered wire.
Old Aug 1, 2006 | 01:18 AM
fordinmudd's Avatar
fordinmudd
the test light sounds easy to use.where would i touch it to inside the connectors?and if it doesnt light then i need a new motor?..anyway the local junk yard wanted 40.00 for a used motor i thought that was kinda high for a junk yard one.
Old Aug 1, 2006 | 12:42 PM
Franklin2's Avatar
Franklin2
Some of the testlights have a sharp point on them, so you can hook the clip to a good metal ground, and then just poke the wire through the insulation with the sharp point.
Old Aug 1, 2006 | 04:18 PM
fordinmudd's Avatar
fordinmudd
ok i got a test light today at pep boys it says to ground the clip part of it and then point and touch the probeto the point being tested.bulb will light it voltage is present it says.red light indicates pos polarity and green light indicates neg polarity.it comes to a fine point on the end of it.im guessing i touch someplace inside the wiper motor to do this?not really sure how.i know you say poke the wire but the wire clip has about 9 wires going to the wiper motor what one do i poke? unless i bought the wrong tester? thanks for your help.
Old Aug 1, 2006 | 04:55 PM
Franklin2's Avatar
Franklin2
Here's the diagram
Check the darkgreen wire.
