Sponsored by: Real Truck
High pitch screech
Old Sep 16, 2010 | 10:02 AM
Bitter Salt's Avatar
Bitter Salt
High pitch screech
I have a high pitch screech when the turbo boost gets above 20psi, especially when cold or towing. The dealer already bent me over to change the gasket between the Y pipe and the egr cooler. Now they want to replace the exhaust manifold gaskets. Seems to me the problem is linked to the turbo. Anybody have the same problem or know what it is?
Old Sep 16, 2010 | 05:20 PM
bpounds's Avatar
bpounds
When my turbo screeched it was broken and rubbing the housing internally. Mine screeched under load, but was okay at moderate throttle.
Old Sep 17, 2010 | 09:00 AM
Bitter Salt
Thanks! Did it cost a lot to fix?
Old Sep 17, 2010 | 09:44 AM
bpounds's Avatar
bpounds
Didn't cost me anything, because I was under warranty. I believe they replaced the whole thing with a refurb.
I'm not convinced that is your problem, and was just relaying my own experience as a possible issue.
Old Sep 17, 2010 | 10:50 AM
Bitter Salt
No problem, I was just trying to get some other opinions. The dealer thinks its the exhaust manifod gaskets and I don't I think replacing them would be a waste of time and money. Thanks for your input!
Old Sep 17, 2010 | 10:59 AM
bpounds's Avatar
bpounds
I think your dealer is full of crap. You should ask down in the 6.0 forum for more opinions. If it is an air leak, it would probably be the rubber boots, not exhaust.
IHateCommieCars
May 24, 2015 05:31 PM
stormblue
15
Apr 5, 2015 02:49 PM
sand_fiend
Mar 20, 2014 12:12 AM
drizzie27
19
Jun 9, 2012 10:46 AM
conan777
16
Sep 15, 2005 09:43 PM
