Hmm... I may have to dig a little deeper into this issue. Maybe it's something about the newer tranny's design or maybe the material. They're not making manual tranny's out of a aluminum now are they? I mean, the casing I get- but the gears is what I mean.
ATF is what it takes. Actually, a lot of manual gearboxes take ATF. I'm not sure of the particulars, but something to do with the synchros and proper shifting, blah blah.
I do know that the previous owner of one of my former SHO's put gear oil in the 5-speed trans, and it wouldn't shift for crap. Changed it to ATF (like it calls for), and it shifted great.
It probably has something to do with consistency. Gear oil is a lot thicker than ATF, so particularly when it's cold out it's tough shifting until it gets nice and hot. I remember this from when I owned my 75 chevy- every freezing cold winter morning I'd give the old beast a good 20 minutes to warm up just to make shifting easier.
But I'm still not convinced that ATF is all I would put in a manual. I don't currently have a manual in my truck, but if I ever swap or get another truck w/ a manual in it, I'd be more inclined to experiment in finding a mixture with the two. My reasoning here is that age and mileage mean almost nothing to gear oil, and it stands up to the heat a lot better. ATF will break down faster just from the heat, even if it is over a year or two.
I'm curious- how often does Ford recommend changing the ATF in a manual tranny?
