I cut the hose off at the back of the hubs and left about an inch so I could stick a drywall screw in it. Then pulled the remaining hose off the nipple by the shock and capped with a vacuum plug.
Here's a pic of the vacuum plug at the shock. I don't have a pic of the screws.
thanks guys sound easy enough yall have pictures of everything this place is great what happens if the vaccum lines stay hooked up just curious
Nothing, but if you develop a vacuum leak inside the hubs around the yellow O-ring (part of the OEM autolock mechanism), your HVAC system will default to defrost only.
