Looking for pictures of other peoples dual exhaust setup on there F-100/F-150 4x4
not yet
I haven't done it yet, but am in the same situation. My plan is to run the drivers side over to the pass side, to the rear and exit both pipes on the pass side. I am running 351W and Nv4500 with a Bw4401 Tcase and just don't have the room on the drivers side. It is hard to see here, but once i Installed the midship tank it convinced me. I put the heat shield back in and will position the mufflers vertically under the heat shield. If I recall, my mufflers are bottom in, center out. I have 8-9 inch resonators for the tips.
Doug
Doug
on
1 Post
Thanks for the added input, as always i enjoy more input from anyone, so if you have something to add, or pictures to show, then don't be afraid to post them,
my truck's details and picture is in my signature, so your running a 351w in a 4x4, i haven't seen that on these trucks yet, as i know the 351w was not available on these '73-'79 trucks, and neither was a 302w in a 4x4 for this generation,
also Doug do i see rear Disc brakes?, i am assuming your truck is a F-100/F-150?, so your running a 9" right? if so i would love some details on how your doing rear disc brakes, i hear the full-size Lincoln's and Ford LTD's from the mid to late 70s have rear discs on there 9", so i am assuming they share the same lug pattern size as our trucks? so is that where you got your setup? or is it a aftermarket kit? also are you running a F-350 brake booster for the brakes?
my Ford 9" is 3.50 and its a open diff, and its the 31 spline,
-Brent
-Brent
F250
-Brent
-Brent
Here it is sitting in the frame.
Doug
on
1 Post
-Brent
-Brent
My 79 that I just aquired has duels, the drivers side comes over the trans, then it crosses back over after the t-case crossmember, they exit out the rear (short box stepside) by the lights. I found some paperwork under the seat that said "heart throb exhaust".
On a 78 shorty fleetside, I had duels custom bent and they went right over the t-case crossmember on the drivers side, they exited out in front of the rear tires, it's been a while but as I remember there was plenty of room. Probably 2 1/2" pipes?
coopster17
09-28-2016 05:37 PM
Bigbluedent1977
08-21-2016 07:55 PM
Bigbluedent1977
04-24-2016 06:49 PM
parkland
General Diesel Discussion
04-18-2012 01:52 PM
1977f150xlt
20
03-14-2009 03:57 PM
