Sponsored by: Real Truck
IAH delete throwing ses code.
Old Sep 15, 2010 | 05:11 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Anyone do the delete and the have it cause the ses to come on for low voltage. I live in Vermont but hasn't been cold just cool. It happened today after filling up.I drove the 0.7 mile to work no light, sat for 5 hours, in mid 50's,start it up and light on. I thought this only worked under certain conditions. This is on a 01 excursion with 7.3. Thanks.
Old Sep 16, 2010 | 12:44 AM
brian42's Avatar
brian42
Veteran: Navy
I have done the mod, but in Southern CA it never really gets cold enough to throw a code. Here's what activates the AIH (from www.dieselsite.com):
"To reduce white smoke during long idle periods at low ambient temperatures, the PCM will activate the intake air heater. Specific conditions must be present before the heater is activated: "
-ambient temperature must be below 0 deg C (32 deg F)
-engine oil temperature must be below 55 deg C (131 deg F)
-vehicle power must be between 11.8 and 15 volts
-parking brake must be applied on manual transmission vehicles
-the transmission must be on park or neutral on automatic transmission vehicles
-glow plugs must be off
If you are throwing the P0541 code you can buy this to get rid of it:
Air Intake Heater Plug Code Eliminator P0541
Old Sep 16, 2010 | 09:32 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Awesome thank you for posting that fix. For $15 I guess it is worth a try.
Old May 23, 2011 | 02:34 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Hello, been a while. I did buy the wire but not sure which posts it hooks to. Does anyone know and could show or tell me? thank you.
Singing River Farm
New Member Introductions
Jan 24, 2014 10:05 AM
Pyancey
Jul 19, 2013 09:55 PM
wildstang
Vermont Chapter
1126
Apr 30, 2012 10:47 PM
GreatNorthWoods
Sep 17, 2009 03:45 PM
Darth Baiter
Jan 25, 2006 11:15 AM
