Service Engine Light - No Code
Old Jul 18, 2013 | 04:51 PM
Pyancey's Avatar
Pyancey
I have an 01 excursion withe the 7.3L. My SES light came on a while back and had a replace #8 glowplug code. The truck started blowing white smoke and then would not start so i had it looked at. The service guy said I needed two injectors. I asked him to replace the glowplug while at it. Now the SES light is still on and there is no code.... I have disconnected the batteries and hooked them back up to try to reset it. it worked for a few minutes but came back on. any ideas??
Old Jul 18, 2013 | 06:08 PM
snakedoc's Avatar
snakedoc
what are you checking the codes with.
Old Jul 19, 2013 | 08:52 AM
Pyancey's Avatar
Pyancey
i first pulled the code with the programer i have. it is a Diablo .... The guy at Spartan Diesel shop said he could not pull a code with his programer.
Old Jul 19, 2013 | 08:05 PM
F350-6's Avatar
F350-6
It doesn't sound like much of a diesel shop if he doesn't have a scanner that can pull a code from the 7.3 diesel.
Are you looking for a way to get the code pulled, or a shop to fix it for you?
Old Jul 19, 2013 | 09:55 PM
Pyancey's Avatar
Pyancey
[QUOTE=F350-6;13356005]It doesn't sound like much of a diesel shop if he doesn't have a scanner that can pull a code from the 7.3 diesel.
Are you looking for a way to get the code pulled, or a shop to fix it for you?[
Would like to fix each one.
racking Hard
May 12, 2019 07:34 AM
bvbunky195
Escape & Escape Hybrid
Apr 30, 2010 07:32 PM
That_Guy
Jan 2, 2008 06:45 PM
Sil307
Sep 1, 2004 07:21 AM
